Author Topic: Router Bit Question  (Read 3311 times)
Baezl
  • Last login:August 24, 2024, 07:11:26 am
Router Bit Question
« on: April 17, 2014, 04:19:42 pm »
Hey there, I was wondering if someone can point me in the right direction.  I am going to build a bartop and wanted to round the edges.  I seen some videos on youtube where people use a roundover bit but had a couple questions.
I am going to use 1/2" MDF and was not quite sure on the size of bit to buy.  Can someone suggest a size?  I been reading through the forums but I cannot find much discussion for 1/2" and bit size.
When you use a roundover bit, is the wood/mdf flipped and is it done to both sides?
Another question, after I build my main template, do you use a pattern bit or flush trim bit to replicate the second side?
Any help is highly appreciated.  Until then, I will keep trying to search for more info.
Luis
Slippyblade
Re: Router Bit Question
« Reply #1 on: April 17, 2014, 04:50:59 pm »
If your material is 1/2" then you would use a 1/4" round-over bit.  Yes, you route the first side, flip the material, then route the other side.
Baezl
« Reply #2 on: April 17, 2014, 05:05:54 pm »
Thank you!
Slippyblade
« Reply #3 on: April 17, 2014, 07:05:56 pm »
When I did my cabinet, I cut out the first side and used it as a template.  Traced it onto the second piece of wood.  Cut a little outside the line.  Then I clamped the two together and used a sander to bring them even with each other.
A pattern bit or flush trim would have made this MUCH easier.  ;D
Baezl
« Reply #4 on: April 17, 2014, 10:13:34 pm »
Thanks for all the input!!  Through different post on this site, I printed out a side template I found on this forum at kinkos to scale.  I cut it with scissors and taped it to thick card stock and cut it out.  Used it to draw the template.  Time to buy some tools for the weekend.  I got three attempts on this one piece of wood.  Thanks again. It is highly appreciated.  I'm on this forum everyday!  I went down this rabbit hole and now I am addicted.
Luis
kahlid74
  • Gaming for a better future!
    • GamersAnon
« Reply #5 on: April 21, 2014, 12:39:03 pm »
A couple pieces of advice:
1). When cutting the straight lines use a straight edge of some type.  Many of us use Flush Trim bits to cut along straight lines.  For you, you could clamp a board down X inches from the cut all the way along.  That way the cut is uniform without you have to "eye" it.
2). Do some cuts on practice wood, whether it be scraps or anything else.  You need to get a feel for how to move the router.  If you don't think you can make the curved lines well, route 1/4" to 1/8" away from them and then SAND the finished product to the line
Baezl
« Reply #6 on: April 22, 2014, 10:54:54 am »
Thanks for all the input!!  After I was happy with my template, I took everyone's advice, practiced on scrap and went to town.  The initial template was a lot of work but came out good.
Now I traced it on MDF, rough cut it and used a router with a flush trim bit.  Easier than I thought!!
Picked up the router below new from sears for $41.  Saw it on slickdeals yesterday morning so jumped on it.
Thanks again!!
Luis
RandyT
  • Last login:July 21, 2025, 02:16:03 pm
    • GroovyGameGear.com
« Reply #7 on: April 27, 2014, 10:26:21 pm »
Just ran across this little gem.  Looks like it will round over both sides of a 3/4" panel in one pass.  Would work for 1/2" as well, giving a shallower curve, which may be desirable.  The only hitch is that it's not practical for a "one off", as a proper template is necessary.  But for multiples, it looks like it would be just the ticket.
kahlid74
    • GamersAnon
« Reply #8 on: April 30, 2014, 12:42:18 pm »
Yeap, those bits are awesome but did you ever look at the price of those suckers?  Like the super nice flush trim bit ones are like $100+ bucks.  I would imagine this one would be ~$100 ish too.
RandyT
« Reply #9 on: April 30, 2014, 01:57:33 pm »
The one I linked to looks like it can be had for $35 shipped.  If someone was cranking out panels, it would pay for itself pretty quickly.
Edit:  Sorry, that one was without the follower bearing...This one with the bearing is closer to your estimation ($82).  Still not terrible in a production situation.
« Last Edit: April 30, 2014, 02:00:57 pm by RandyT »
