Author Topic: Best monitor for displaying the marquee?  (Read 13309 times)
Lucky S.O.B.
  • Last login:June 02, 2021, 03:02:50 pm
  • Mmmmm.... Donuts!
« on: March 11, 2014, 06:35:40 pm »
So the other day I stumbled across this thread talking about how to setup a 2nd monitor for a marquee: http://forum.arcadecontrols.com/index.php?topic=118741.0 and at the time the "best/biggest" monitor was http://www.amazon.com/XO-Vision-RM122-Monitor-Electronics/dp/B00527FGVY/ref=sr_1_1?ie=UTF8&qid=1363553036&sr=8-1&keywords=%28XO+Vision+RM122+10.2%22+TFT+LCD+Rear+View+Monitor%29
I am planning to build a 4 player pedestal cabinet that attaches to a wall mounted TV, but would like the marquee displayed like this http://forum.arcadecontrols.com/index.php/topic,117320.0.html
Any help would be appreciated!
  • Last login:Today at 04:52:49 am
Re: Best monitor for displaying the marquee?
« Reply #1 on: March 11, 2014, 07:15:21 pm »
Here are several threads you may want to check out.
Marquee shaped monitor
Ultra-wide LCD Screen for the Ultimate Marquee
Unstupid
« Reply #2 on: March 12, 2014, 07:33:38 pm »
also check out a company called vitrolight... they also sell on ebay under the same username.
astrog21
  • Last login:December 05, 2015, 06:17:48 am
« Reply #3 on: March 16, 2014, 03:20:58 am »
You could use something like a BetaBrite Prism (betabrite.com). It is a LED screen, but can display images through a USB port on a PC. It is probably not high enough though :'(.
jlampc
  • Last login:February 02, 2022, 07:33:58 am
  • I am not an animal !!! I am a gamer
« Reply #4 on: May 29, 2014, 12:11:34 pm »
Not sure if this is helpful but, I just got a 25 inch 21:9 monitor for a Digital marquee to use with a MAME cab. Its the LG 25um65. Its a little over 24 inches wide and 11 inches tall. I had been considering an ultra wide monitor, but found that they were way out of my price range until I found this. I actually picked this one up for $219 + tax at Costco. Not sure how wide you wanted it, but its with in the range of a standard Marquee. The best part is its an IPS panel with Good Angles.. so it doesnt seem dim or blurry off angle.
keep an Eye out for it ...
lamprey
« Reply #5 on: May 30, 2014, 04:29:51 pm »
Not 100% sure what you are looking for, but you can get some 21:9 monitors for a reasonable price (like Jlampc mentioned):
http://www.amazon.com/LG-25UM65-25inch-2560x1080-UltraWide/dp/B00JP4NWQG
http://www.amazon.com/AOC-29-inch-IPS-Q2963PM-21/dp/B00BOEUQZK
I've seen wider aspect ratios someplace (vitrolight as mentioned by Unstupid). I don't know where you can buy that brand. But, if you search for "Streched Bar LCD" you can find some results (ebay).
http://www.vitrolight.com/en/ClassSummary.html?cid=93
