Author Topic: Exit emulator problems  (Read 3635 times)
Larsarcade
  • Last login:December 27, 2014, 05:54:01 pm
« on: February 03, 2014, 08:52:08 am »
Hi, I have som trouble with My arcade. Im using mala, I have configured a certain button to exit the emulators and it works fine with nestopia, genesis and the gameboyadvance emulator. But when I play forexample snes in zsnesw and push exit, the emulator continues to play and I have to crtl alt delete to stop it. And mala crashes and a fault Message pop out.
If I configure the same exit button in the zsnesw emulator to exit it works fine but then returning to the gamelist screen, mala has been set to be in the background and I have to click on the mouse once to set the mala on the front. This is also happening with My mame emulator that Im using.
Any suggestion how to solve this problem? And sorry for the spelling Im Swedish.
empardopo
  • Last login:January 18, 2026, 03:32:00 am
    • My personal forum
Re: Exit emulator problems
« Reply #1 on: February 05, 2014, 03:20:00 am »
Have you using the last version of MALA?
Could you put any image of your MALA configuration?
You also could take a look to my AllInOneFYC program.
Greetings!
  • Online Online
  • Last login:Today at 07:29:44 am
« Reply #2 on: February 05, 2014, 01:23:41 pm »
First try using hotkeys in Mala first:
http://wiki.arcadecontrols.com/wiki/Mala_Config#Options_2
If that doesn't work, you can try a program called closemul:
a little info in this thread-
http://forum.arcadecontrols.com/index.php?topic=132464.0
If that doesn't work, we can move on to autohotkey.  :lol
Code: [Select]
ESC:
process, close, zsnesw.exe
empardopo
    • My personal forum
« Reply #3 on: February 06, 2014, 04:59:05 am »
Here, you can see a tutorial in spanish.
I think in Zsnes you can config a button of your control panel to exit.
Greetings!
Larsarcade
« Reply #4 on: February 10, 2014, 05:59:57 am »
Thanks it works great now!
