Author Topic: Daphne & ArcadeVGA  (Read 1101 times)
Zeeman
  • Last login:March 08, 2008, 11:25:21 am
Daphne & ArcadeVGA
« on: November 29, 2003, 01:56:58 pm »
I have an 15hz arcade monitor and the ArcadeVGA card.  When I start Dragon's Lair using Daphne only the top half of the video is being shown.  I'm guessing this is because the video was captured as non-interlaced and is 2x the height I need.  Does Daphne have command switch or something to correct this?  Or do I need to re-encode all the video to get it to work right?  :(
Re:Daphne & ArcadeVGA
« Reply #1 on: November 29, 2003, 05:07:38 pm »
I'm not sure 100%, but I seem to remember Daphne has a 'video hardware acceleration' mode or similar.  Try toggling it to see if it makes a difference...
Also, check what resolution Daphne is running in, I'd suggest setting it to 640x480 :)
dreamfreak
  • Last login:August 23, 2005, 08:10:58 am
« Reply #2 on: December 03, 2003, 03:11:32 am »
hi,
I
dreamfreak
« Reply #3 on: December 03, 2003, 01:12:11 pm »
hi,
it was the button "disable hardware acceleration (MPEG only)"
now it works fine
thx again a lot to minwah  ;D
