Author Topic: can I make a complex control panel that connects via 1 single usb?  (Read 1540 times)
zipdaman12
  • Last login:February 26, 2016, 07:43:30 am
Hello all,
I have a made a complete mame cabinet years ago and it has served me and my family very well.  I am toying with the idea of making a control panel that I can connect to my Home Theater PC; using my HDTV as a monitor.  I have the software installation complete leveraging the Gamex front end and I am using a wired xbox 360 controller but as you all know its notg the same as using actual joysticks and arcade style buttons.
Here is my question.  I have an ipac (usb)_ as well as 2 usb interfaces to use with my Happ controls spinner and Trackball.  I would like to build a control panel using all of these interfaces, but I don't want to have to plug 3 separate uysb cables into my PC.  Is there a way to include a trackball, spinner as well as other buttons and joysticks and use only 1 usb cable to my PC?  is a usb hub a viable option?
Any and all comments are appreciated.
Jack
« Last Edit: January 04, 2014, 01:37:01 pm by zipdaman12 »
Fursphere
  • Last login:Yesterday at 04:15:45 pm
Re: can I make a complex control panel that connects via 1 single usb?
« Reply #1 on: January 04, 2014, 02:24:50 pm »
Mount a USB Hub on the panel, connect everything to that.  Then have one USB cable that runs to the PC.
Might need to be a powered hub though - you'll have to test.
  • Last login:Today at 12:54:01 am
« Reply #2 on: January 04, 2014, 04:06:17 pm »
An unpowered hub will almost certainly work for your setup.
Remember that unpowered hubs have a 100mA/port limit according to the USB spec, even though many hubs can exceed this.
I've been using the following on a test setup with no problems:
Belkin USB 2.0 4-port hub available here
Mini-Pac Opti w. U-Trak
TT2 Spinner + encoder
LED lighting circuit for trackball and admin buttons that draws ~86 mA
You can plug the hub into a Neutrik NAUSB-W-B with the "A" connector on the inside and the "B" connector on the outside of the enclosure. (undo 2 screws and reverse the barrel)
From there, one USB A-B cable connects your CP to the HTPC.   :cheers:
You can solidly mount the hub using 5 screws and PEX plastic pipe -- details here.
« Last Edit: January 04, 2014, 04:15:08 pm by PL1 »
