Author Topic: Quick computer question(OT!!)  (Read 1999 times)
SNAAAKE
  • -Banned-
« on: November 27, 2003, 10:08:47 pm »
I can have a cdrw and a dvd+rw on the same IDE port?
The board only has 2 IDE ports.
Now I got a cdrw and 2 HDs.
Can I put the cdrw on slave and the dvdr+w on master ???
(or the other way around)
http://www.compusa.com/products/product_info.asp?sid=3FC53E8097CE17F&product_code=303196&pfp=BROWSE
Really really want this for $100 but 16X write is lame... :P
« Last Edit: November 27, 2003, 10:12:35 pm by SNAAAKE »
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
Re:Quick computer question(OT!!)
« Reply #1 on: November 27, 2003, 10:11:33 pm »
I'm 98% sure you can do that. I have it setup like that on my main PC, no problems whatsoever.
SNAAAKE
  • -Banned-
« Reply #2 on: November 27, 2003, 10:15:36 pm »
Okay so how do you have it ?
dvdrw on IDE1 master and cdrw on IDE1 slave ?
Anyone else  ?
« Last Edit: November 27, 2003, 10:16:18 pm by SNAAAKE »
EndTwist
  • Arg.
« Reply #3 on: November 27, 2003, 10:19:40 pm »
I have it so both CD-RW and DVD-RW are on the same ide.
SNAAAKE, pop on aim for a sec,  i gotta ask you a question.
pointdablame
« Reply #4 on: November 27, 2003, 10:21:06 pm »
it doesnt really matter what you set as master/slave, although with 2 hard drives, and 2 optical drives, your ideal setup would be a hard drive and optical drive on both of the IDE channels with the hard drives being the master and the optical drives being the slave.
« Last Edit: November 27, 2003, 10:21:45 pm by pointdablame »
first off your and idiot
2600
« Reply #5 on: November 27, 2003, 10:30:32 pm »
Ok, I started writing a tutorial for you but it got kinda long so I didn't.  But if you or anyone want it as a reference I'll be glad to post it.
For your situation, personally I would just put the Dvd drive as master on the secondary channel(Second Port).  It can burn Cds and depending on your power supply would help with all that. Four drives is a lot of juice.  If you want to use both I would put the DVD as master on the secondary channel and the CDRW as slave on the secondary chanel.
slycrel
  • Last login:June 25, 2025, 07:42:34 pm
  • Mmm... Portal.
« Reply #6 on: November 27, 2003, 11:42:34 pm »
  Agreed,  IIRC if you mix up HDD's and CDR's it's possible to slow down your hard drive.  I know for sure that if you have a fast and slow drive on a single IDE cable, they both go at the slow drive's speed.
  For what it's worth.  You shouldn't have any problems with what you're talking about though.
pointdablame
« Reply #7 on: November 28, 2003, 12:16:11 am »
actually "mixing" hard drives and optical drives does the exact opposite of what you said slycrel.
By putting the two hard drives on two seperate IDE channels, you allow each drive to have a max amount of the IDE channel's bandwith. Therefore, whenever you have to transfer data from one drive to another, or when programs are being accessed from both drives, you are not bogging down one IDE channel with both hard drives. It is a much better option to put one hard drive and one optical drive on an IDE channel whenever possible.
As far as four drives using too much juice, I don't think that carries much weight. For a normal system, you can run 4 drives and everything else on a 350watt PSU with no problems, and 350 is about the minimum these days if a system is anywhere near new. Maybe worry about that SNAAAKE if you are on an older system with a very small PSU (300w or under) but otherwise, there is no way that those drives are taking up too much power.
SNAAAKE
  • -Banned-
« Reply #8 on: November 28, 2003, 12:20:59 am »
Allright thanks everyone,decided to get the drive.
The powersupply is 350w so wont have any problem.
pointdablame
« Reply #9 on: November 28, 2003, 12:23:43 am »
Also SNAAAKE, you may want to consider a Lite On dvd burner.
NewEgg has a 4x DVD+R, 4x DVD+RW, 40x CDR, 24x CDRW for only 95 bux, 103 if you want a beige drive. Click the link below and scroll to the products that are 95 and 103 respectively for more info. They are very good drives and quite a bit faster than the one you posted.
http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=5&manufactory=1336&DEPA=1&sortby=14&order=1
SNAAAKE
  • -Banned-
« Reply #10 on: November 28, 2003, 12:26:40 am »
actually,getting the exact same one from bestbuy(been looking around).
thanks for the link :)
pointdablame
« Reply #11 on: November 28, 2003, 12:28:28 am »
No problem, they are great drives. Enjoy.
I'm actually planning on getting one very soon also. i put one in a system for a friend of mine a few weeks back and he's been loving it.
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #12 on: November 28, 2003, 01:31:27 am »
Anyone else  ?
  Uh, pardon me, but I find your question offensive.
/Steve
night
  • Last login:January 09, 2018, 02:08:19 pm
« Reply #13 on: November 28, 2003, 10:36:24 am »
haha, that is so stupid. this country is so f***in pathetic.
bunch of whiny ass pansies.
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
« Reply #14 on: November 28, 2003, 11:04:19 am »
Just want to chime in to say that pointdablame's advice is spot-on.
SNAAAKE
  • -Banned-
« Reply #15 on: November 28, 2003, 01:01:09 pm »
Anyone else  ?
/Steve
 :D ::) :P
....... :-X
They got nothing better to do I guess...
« Last Edit: November 28, 2003, 01:10:27 pm by SNAAAKE »
slycrel
  • Mmm... Portal.
« Reply #16 on: November 28, 2003, 01:24:43 pm »
  Sorry, you are right.  The first portion of what I said was wrong (I don't remember for sure on that one), but the second half was right -- I just wasn't clear.  You don't want to put two HDD's on the same cable or you'll have issues.  Apologies for the confusion.
pointdablame
« Reply #17 on: November 28, 2003, 01:47:24 pm »
hahahaha @ that article.  People in this country just aren't happy unless they are complaining about the latest "injustice." I got a good laugh out of the article tho, so thanks.
and glad I could help with the hard drives, it's what happens \when you build too many computers heh. I'm up to 12 or so I think now.... you just kinda learn these things as you go along.
Hoe
  • Last login:September 05, 2004, 01:17:09 pm
« Reply #18 on: November 29, 2003, 04:45:34 am »
I've herd of a lot of Lite Ons dieing fast. I've never bought one, but just warning.
