Author Topic: MAWLER: A MAWS Recreation  (Read 110459 times)
  • Last login:June 25, 2025, 03:09:16 pm
Re: MAWLER: A MAWS Recreation
« Reply #40 on: November 17, 2014, 11:53:49 am »
Thanks, ids. No need to hurry on my account, but I appreciate the work you put into this one. I have been enjoying mawler. Really good for dicing up romsets to match exact criteria to put exact roms into a specialty cabinet. This has become standard software on all my computers.  :cheers:
ids
  • Last login:Yesterday at 08:56:20 pm
  • Fighter Captured
« Reply #41 on: November 17, 2014, 01:36:42 pm »
I so glad to hear you're finding it useful!
Sorry, was hoping to get a fix out yesterday but unable to find free time :(  I should have something within a day or two.
ids
  • Fighter Captured
« Reply #42 on: November 17, 2014, 09:44:27 pm »
Update posted at the usual URL.  Please keep a backup of your current version just in case I broke something :)
« Reply #43 on: November 18, 2014, 10:54:32 am »
Thanks man! I'll check it out.  :cheers:
adder
« Reply #44 on: November 19, 2014, 08:17:23 pm »
hi im a bit lost, just trying to get a list of the gambling/fruit machine type stuff, but not sure how to search for those with mawler. i added mame155 xml and catver.ini to mawler, am i missing something?     i dont seem to have any info on 'category' and 'genre' (see pic below);  im assuming i need that info before i can generate the lists im after?  nothing apart from 'any' is available in the 'genre' and 'category' drop down menus on the left..
nitrogen_widget
  • Last login:May 23, 2025, 02:30:58 pm
« Reply #45 on: November 20, 2014, 08:43:05 am »
The same.
Its easier to just put the ROMs you want on the PC than filter them with the front end.
At least for me it is.
DudeRegular
« Reply #46 on: January 31, 2015, 10:45:36 pm »
Same issue here. Nothing in Genre or Category. I have defined that mame.xml and catver.ini. The version added info that appears to be in the catver.ini file is not listed in MAWLER either.
okambi
  • Last login:June 18, 2023, 10:10:48 am
« Reply #47 on: June 19, 2015, 02:13:26 pm »
Hey there, while running this on a Mac from the download link in the first post I get the following stack trace:
Code: [Select]
java.beans.IntrospectionException: Cannot find class based on missing property 'Machine' on 'class ca.ids.mame.model.Mame
at xmc.util.xml.GenericContentHandler.findClass(GenericContentHandler.java:229)
at xmc.util.xml.GenericContentHandler.createDataObject(GenericContentHandler.java:256)
at xmc.util.xml.GenericContentHandler.init(GenericContentHandler.java:132)
at xmc.util.xml.GenericContentHandler.<init>(GenericContentHandler.java:112)
at xmc.util.xml.GenericContentHandlerFactory.createHandler(GenericContentHandlerFactory.java:71)
at xmc.util.xml.PreContentHandler.nextHandler(PreContentHandler.java:184)
at xmc.util.xml.GenericContentHandler.nextHandler(GenericContentHandler.java:539)
at xmc.util.xml.GenericContentHandler.startElement(GenericContentHandler.java:340)
at xmc.util.xml.SimpleXMLParser.getElem(SimpleXMLParser.java:132)
at xmc.util.xml.SimpleXMLParser.handleContent(SimpleXMLParser.java:157)
at xmc.util.xml.SimpleXMLParser.getElem(SimpleXMLParser.java:135)
at xmc.util.xml.SimpleXMLParser.parse(SimpleXMLParser.java:92)
at xmc.util.xml.SimpleXMLParser.parse(SimpleXMLParser.java:82)
at xmc.util.xml.PreContentHandler.load(PreContentHandler.java:150)
at xmc.util.xml.PreContentHandler.<init>(PreContentHandler.java:135)
at xmc.util.xml.PreContentHandler.<init>(PreContentHandler.java:111)
at xmc.util.xml.PreContentHandler.<init>(PreContentHandler.java:67)
at xmc.util.xml.ParserHelper.parse(ParserHelper.java:100)
at ca.ids.maws.DataAccess.getMame(DataAccess.java:319)
at ca.ids.maws.DataAccess.list(DataAccess.java:146)
at ca.ids.maws.Cache.getFieldValues(Cache.java:18)
at ca.ids.maws.gui.AdvSearchList2.createCB(AdvSearchList2.java:188)
at ca.ids.maws.gui.AdvSearchList2.addDropList(AdvSearchList2.java:153)
at ca.ids.maws.gui.AdvSearchList2.addCB(AdvSearchList2.java:143)
at ca.ids.maws.gui.AdvSearchList2.addCB(AdvSearchList2.java:139)
at ca.ids.maws.gui.AdvSearchList2.setGUI(AdvSearchList2.java:74)
at ca.ids.maws.gui.AdvSearchList2.<init>(AdvSearchList2.java:41)
at ca.ids.maws.gui.DeluxeSearchPanel.<init>(DeluxeSearchPanel.java:35)
at ca.ids.maws.gui.Maws2.init(Maws2.java:227)
at ca.ids.maws.gui.Maws2.access$000(Maws2.java:32)
at ca.ids.maws.gui.Maws2$1.run(Maws2.java:176)
at java.lang.Thread.run(Thread.java:695)
java.lang.IllegalStateException: Cannot find data class for 'ca.ids.mame.model.Machine; nowhere to put it's attributes
at xmc.util.xml.GenericContentHandler.init(GenericContentHandler.java:144)
logout
[Process completed]
Stiletto
  • Last login:September 27, 2022, 11:41:36 pm
  • MAME me.
« Reply #48 on: June 19, 2015, 11:55:23 pm »
Unrelated (?) but FYI, the XML format changed in 0.162. :)
okambi
« Reply #49 on: June 20, 2015, 08:42:08 am »
Thank you for the info, using an older version worked great. Much appreciated.
Stiletto
  • MAME me.
« Reply #50 on: June 20, 2015, 09:51:04 am »
Hah, okay - I wasn't sure if 0.161 would fix it.
MAWLER needs to be updated now to support both 0.161 (and below) and 0.162+, I hope he can do it. :)
ids
  • Fighter Captured
« Reply #51 on: June 22, 2015, 10:16:57 pm »
Sorry all, didn't see the activity here since my last post.
Adder/DudeRegular - still having this problem?
I'll try to get an update together for .162+.  Hopefully XML changes are small.  Sorry, been stupidly busy, falling way behind on a lot of things :(
keilmillerjr
  • Web Developer.
« Reply #52 on: September 08, 2015, 09:41:30 pm »
Using the app on mac with mame.xml and cater.ini for version 0.161. Categories are not listed.
Stiletto
  • MAME me.
« Reply #53 on: October 02, 2015, 05:24:58 pm »
ids, are you ever coming back to this project? :)
ids
  • Fighter Captured
« Reply #54 on: October 02, 2015, 06:04:05 pm »
Yeah, sorry, free time has been quite limited for a while now.  I did take a look recently...at which point I remembered I was in the middle of reworking some stuff, so it's in a state of not compiling, which makes it hard to do simple fixes :(  I'll get back to it as soon as I can.  Sorry.
ids
  • Fighter Captured
« Reply #55 on: February 19, 2019, 09:36:25 pm »
Trying to get back to this, the changes in the mame.xml after the MESS merger are non-trivial.  I'm currently working on compatibility with MAME 0206.   Just thought I let people know it's not dead, it's just coming out of a long coma.  And new filters will likely be required, such as: is this a MAME game or other? (non-trivial filter).  Sorry for the long hiatus, life has ways of sending you sideways for a while.  I really hope to post an updated binary before long.  I've been reviewing the to-do list and am eager to knock off some of the listed items.  Please feel free to hit me up for prioirties.   Can't promise anything until I complete support for the latest mame.xml though  :-\
Appreciate all the support along the way, and hoping to find time to maintain this going forward.
SORHP
  • Last login:July 14, 2025, 12:28:55 am
« Reply #56 on: February 20, 2019, 12:37:40 am »
Way to go, keep up the good work!
Games: Super Punch Out, Fix It Felix Jr, DK, DKjr, DK3, PC10, UMK3, TRON, MS-Pac, Pac, Centipede (2x), Robotron, Galaga, Space Invaders, Street Fighter 2 CE, X-Men vs SF, BuckHunter HD, 2X Custom Vewlix, Custom Nintendo VS 3/4, Atomiswave
ids
  • Fighter Captured
« Reply #57 on: February 23, 2019, 12:35:19 am »
OK, think I got it going with 0206 and all related files.  Consider this beta and please let me know if you find any issues.  New link:  mawler0206.zip
Note that, unlike in the past, I've not replaced the previous binary.  I've left the old version where it is to support the pre-MESS merger if anyone needs that.  Going forward, the download filename will include the mame version it supports.
Changes are many.  Some key changes:
  • Added full support for cheat.7z, you can see what cheats are available, search/filter on them, etc  (do not unpack this file, leave it as is)
  • Added support for progetto's "arcade.ini" and "mess.ini" so you can filter based on this distinction, and some other filter options
  • Performance - working on it, but since the merger, files are much, much bigger.   I've got longer term plans for this, but please bear with it for now
If you wish to maintain configuration settings from your old version to this one, keep a copy of "MAWLER.properties" and make sure to put it in the same place that you unpack the new zip file.
Please let me know if you run in to any issues, have any requests, know of other data sources to incorporate, ideas for additional search/filter criteria, etc.
8BitMonk
« Reply #58 on: February 25, 2019, 09:58:26 am »
Great news, thanks for the update!
ids
  • Fighter Captured
« Reply #59 on: March 03, 2019, 07:02:38 pm »
Big Update: Startup time is now very fast.  Updated zip file here mawler0206.1.zip
Loading of data is done in the background so the UI comes up fast.  First time in, however, some indexes need to get built.  Subsequently, start up should be quite respectable.  Depending on load time on your computer, and how fast you can fire off a search, you may not notice any loading at all.
Other stuff in this build:
  • Since we no longer start with a random game, a toolbar button was added to select one at random.
  • Search criteria drop list in the toolbar now has a "Custom.." entry which takes you to the criteria configuration dialog.
  • Sound sample support added.  Samples shown on game screen, and can be played if you have them.  Samples are expected to be under the samples directory where your mame executable is found.
  • Searches optimized in certain cases.
  • Some minor improvements in various areas, and some minor bug fixes (realted to the MESS merger).
ids
  • Fighter Captured
« Reply #60 on: March 07, 2019, 01:03:29 pm »
Just fyi - tested with 0207, no issues detected
ids
  • Fighter Captured
« Reply #61 on: April 01, 2019, 09:31:26 pm »
Another big update available.  mawler0206.2.zip
Added "tags" - when you've got a list filtered just how you like it, "tag" it for future reference.  This can be useful in many ways - for example, if you want to exclude non-arcade games (or whatever) all the time, tag the full list of arcade games, then use the tag combined with other criteria in future searches.  Or save your favourites: "vertical", "horizontal", "4 player", etc.  You can add and remove tags from whole lists or selected items, etc.
Added fully scriptable queries - you can nest criteria, wrapped in parenthesis, with deep levels of AND'd and OR'd logic.  You are no longer limited to just the stuff along the left of the screen.  You can say things like "genre = {Fighter, Gun, Casino}" etc.  You can use =, != (not equals), <, >, <=, >=, etc.  There is a new dialog to help build queries, save queries to reuse later, show recently used queries (whether custom or created from the selections along the left side).  This also includes filtering on tags, of course.  This will eventually lead to command-line functionality.  Here's an example produced from using the left-side stuff:
genre = Driving and resource = Parent and drvstatus = good and chd = no and device = no and system = arcade
Note that you don't need to know the names of the various filter options, they're all in the custom filter dialog, along with known values, etc.  You can also do things like:
((genre = Driving and category = {Race, 'Race Track'}) or (genre = Maze and category = Driving)) and year > 1982
.  Note, as per this last example, textual values that contain spaces must be quoted (either single or double quotes, just be consistent)
Added the ability to copy or move images as well as ROM's (untested, but the code looks ok :) )  See the updated ROM dialog for this.  (I'll be testing this soon as it's something I would really like to make use of).  When copying or moving, whatever form the source was, the target will be as well.  For example, if you have a zip full of images, the copy will create a zip with only the selected game/machine images.  If source was a directory of files, the directory will be created in the target and files moved/copied there.
ROM dialog also has new options: overwrite files in destination directory, include Parent file (useful for split roms, as an example).
Fixed a number of issues with prior version, more performance improvements, ....
Put a metric crap-ton of hours into this, so I'm probably forgetting a good number of things included in this one.
I really need to re-do all the screenshots in the first few posts, so much has changed!
As usual, please let me know your preferences, issues, if it's working for you (or not), etc.
« Last Edit: April 04, 2019, 07:22:43 pm by ids »
ids
  • Fighter Captured
« Reply #62 on: April 03, 2019, 08:49:54 pm »
Some of the new features...
New toolbar buttons and search criteria...  Note that tags can be added to games at any time, so you can build up a very complicated set of games under a single tag.
The button for clearing cache/index files is useful if things seem weird, or you created a "save" file which is slowing you down.  I haven't had a need for this beyond testing and rolling things back.
Creating a custom filter...  You can type whatever you like, or use the drop-downs to help populate things.  All possible criteria show in the first, and all possible values for the selected criteria show in the second.  Or you can review saved filters, save the text as a new filter, delete saved filters....  And all recent history is shown in the list, so you can jump back to anything you've done before.
Enhancements to the ROMs dialog.... can choose to overwrite or ignore if file exists in target directory.  Include parents.  Copy images as well.....
Gotta run, update coming soon, however
ids
  • Fighter Captured
« Reply #63 on: April 04, 2019, 01:04:08 am »
New version available (various improvements) ids.ca/mame/mawler0206.3.zip, and updated first few posts with all the latest details on how it all looks and works.
Not sure if anyone is using this, so this might be the final update.... (please pipe in if this app has value to you, and I'll keep it going)
« Last Edit: April 04, 2019, 01:05:42 am by ids »
« Reply #64 on: April 04, 2019, 05:11:12 am »
I’ve personally loved it! It is an incredible tool. I will update your new version and give it a go. Thank you.  :applaud:
That said, I know this is a ton of work, so don’t feel pressured to keep it up on my account.It really does exactly what I need, and don’t see my rom usage changing anytime soon. I’m getting settled in my ways.
ids
  • Fighter Captured
« Reply #65 on: April 04, 2019, 07:45:58 pm »
Thanks for the kind words Vigo.  I'll keep going as long as there is an audience and someone needs it to do something new (or a bugfix).
Minor update, same link (did not update the version number this time).  Some small bug-fixes (found issues in csv export, custom queries, etc).  Added ability to include header line in csv.  And etc (that's the stuff I did and forgot about already)
nitro322
  • Last login:June 28, 2019, 11:04:55 pm
« Reply #66 on: April 19, 2019, 05:49:34 am »
Hi there.  Just registered to say that I also use and adore this software.  It's the only thing I've been able to find even after all these years to replace the functionality of MAWS.  Just saw that you recently updated it and also you last comment about not continuing it...  as Vigo said, don't feel compelled to continue working on something that may be a hassle if you're heart's not in it, but for what it's worth I do sincerely appreciate your efforts on this.
And while I'm here...  :-)
I'm actually having trouble with the new version.  The full output is here, but I think it's failing on this:
Code: [Select]
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/commons/lang3/StringUtils
        at ca.ids.maws.gui.Maws2.init(Maws2.java:321)
        at ca.ids.maws.gui.Maws2.launch(Maws2.java:234)
        at ca.ids.maws.gui.Maws2.main(Maws2.java:167)
Caused by: java.lang.ClassNotFoundException: org.apache.commons.lang3.StringUtils
        at java.net.URLClassLoader.findClass(URLClassLoader.java:382)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
        at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:349)
        at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
        ... 3 more
I'm running this on Linux.  I've tried icedtea-bin, oracle-jre-bin, and oracle-jdk-bin with the same results.  Based on some quick research it seems like that Stringutils class is part of commons-lang3, so I tried download that and setting the classpath to that jar file, but I still get the same error.  I'm not sure what else to try.
Any suggestions?
ids
  • Fighter Captured
« Reply #67 on: April 22, 2019, 12:44:23 pm »
Thanks for the kind words.  It's not that my heart is not into it, it's more a question of there being an audience for it.  If there is, I'll keep going.  Would also help to know what features are important, so I can focus on those.
As for the bug - I'll try to get a fix out tonight.
ids
  • Fighter Captured
« Reply #68 on: April 22, 2019, 07:19:12 pm »
Updated code - removed dependency on the commons-lang3 library.  Fix found at the same URL.
ids
  • Fighter Captured
« Reply #69 on: May 02, 2019, 07:58:48 pm »
New update at mawler0206.4.zip
Includes:
  • Can print the search results table
  • External data files have a download link, and a "go to site" link
  • Can request MAME to generate the XML with the click of a button
  • Mouse back/forward buttons work now
ids
  • Fighter Captured
« Reply #70 on: June 19, 2019, 06:50:18 pm »
New update at mawler0206.5.zip
Includes a number of bug fixes and various improvements.
Hoopz
  • Last login:June 13, 2025, 09:18:32 pm
  • Intellivision Rocks!
« Reply #71 on: June 27, 2019, 10:52:50 am »
Thanks for keeping this updated.  I am rebuilding my Mame PC and needed info from Maws. It's been a few years since I was fairly active here and I forgot about your program.  Glad to see it's available and you've done a great job in keeping it working for us.
Stiletto
  • MAME me.
« Reply #72 on: June 27, 2019, 05:49:57 pm »
Totally missed that this came back from the dead in February!
I've given you a little love at MAMEWorld, ids! :)
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=382924
ids
  • Fighter Captured
« Reply #73 on: June 27, 2019, 06:15:31 pm »
Very cool, thanks for that.  Hate to point this out after you've been so kind, but... one correction: it does have the ability to launch mame (see screenshot in the third post, joystick icon, top-right area of the toolbar).
Not sure what's up next.  I've been thinking of revamping the UI, as there can be a lot of wasted space.  Thought about adding a web-based UI option, but then someone would have to host it, and some features would be lost, like ROM management, etc.
Open to suggestions.
Stiletto
  • MAME me.
« Reply #74 on: June 27, 2019, 07:30:40 pm »
Fixed. BTW, if you haven't looked at it yet, you should check out MAME's "minimaws" from August 2017:
http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Board=news&Number=368531
https://github.com/mamedev/mame/tree/master/scripts/minimaws
I'm no expert at it, but I've tried it and it works... fully MESS-compliant. :)
joelkolb
  • Last login:March 27, 2021, 02:07:04 am
« Reply #75 on: November 02, 2020, 12:32:42 am »
I just found this utility and it looks like it is very useful. I really want to try it out but I cannot get it to run. After I provide the various files it asks for I get the following message:
When I hit 'OK' it closes out and I have to try running it again but this is as far as it ever gets. The file 'mame.xml' is definitely at the path specified (C:\mawler02605.5\mame.xml) right next to 'maws2.jar'. I have tried several of the previous builds posted in the thread (206.1, 206.2,...) but I have the same issue with them all. I don't know what to do. Please help.
Tiby
  • Last login:January 05, 2023, 01:13:15 pm
  • My "job" is to use lasers... How cool is that!?
« Reply #76 on: November 12, 2020, 01:41:20 pm »
Could it be that you do not have read/write access to the file?
joelkolb
« Reply #77 on: November 12, 2020, 01:46:55 pm »
I definitely have read/write access. I just tested it to be sure. I also ran 'Mawler.bat' from an administrative command prompt. I still get the same message.
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #78 on: December 31, 2020, 10:22:19 pm »
Is the newest version of mawler compatible with older versions of mame.xml?    I'm using mame .151 and mawler is giving me "unable to load mame.xml".  Perhaps its only compatible with mame .162 and later?  An old version of mawler is working fine.
Stub
  • Last login:July 08, 2024, 10:48:14 am
  • Sensory Overload
« Reply #79 on: February 15, 2024, 09:32:18 pm »
Old link is dead. Anyone have a new download location?
Maybe we should put it in a git?
