Author Topic: Daphne problems  (Read 4340 times)
oozing machismo
  • Last login:February 15, 2016, 11:42:55 pm
Daphne problems
« on: November 29, 2013, 12:38:07 pm »
Can someone help me with Daphne.  I keep getting frame file errors.  Here is the daphne log.  Can anyone help?
--DAPHNE version 0.99.7
--Command line is: C:\Users\eric\Documents\Arcade\Daphne\Laser Disk\daphne.exe lair vldp -framefile C:\Program Files\Laser Disk\Dragon's Lair\lair.txt -fullscreen -bank 0 11011001
--CPU : GenuineIntel 950 MHz || Mem : 2048 megs
--OS : Windows NT/2000 || Video : Mobile Intel(R) 4 Series Express Chipset Family
Set 640x480 at 32 bpp with flags: 80000001
Initializing sound system ...
No joysticks detected
Remapping input ...
CFG_Keys() : Unrecognized key name KEY_TILT
CFG_Keys() : input remapping file was not in proper format, so we are aborting
Loading compressed ROM image dl_f2_u1.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u2.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u3.bin...8192 bytes read.
Loading compressed ROM image dl_f2_u4.bin...8192 bytes read.
Could not open framefile : C:\Program Files\Laser Disk\Dragon's Lair\lair.txt
You must specify a -framefile argument when using VLDP.
If you didn't, then this is the problem. :)
Could not initialize laserdisc player!
Shutting down sound system...
Shutting down video display...
I also get  an error when I try to configue the emulator.  This is the error I get with that:
Run-time error '339':
Component 'MSCOMCT2.OCX' or one of its dependencies not correctly registered: a file is missing or invalid
Any help would be much appreciated.
Hambo3
  • Last login:December 03, 2014, 05:19:21 pm
    • insert coin
Re: Daphne problems
« Reply #1 on: November 29, 2013, 02:32:44 pm »
Hi oozing,
Does C:\Program Files\Laser Disk\Dragon's Lair\lair.txt exist?
The MSCOMCT2.OCX error is a windows 7 thing runing an old vb6 application. I forget how i fixed it but it was something like this
http://www.vbforums.com/showthread.php?666309-RESOLVED-Register-mscomct2-ocx-on-windows-7-32-bit
other wise a search for 'MSCOMCT2.OCX windows 7' brings up similar solutions.
If you get this working the config screen can help you out setting it up else you can go the cmd line route but you need this framefile to kick things off usually in a framefile folder.
oozing machismo
Re: Daphne problems
« Reply #2 on: November 29, 2013, 02:40:34 pm »
The file does exist.  The document itself when opened shows:
151   lair.m2v
Also, I am running Vista.  Does that matter with the configuration issue?
ark_ader
  • I glow in the dark.
Re: Daphne problems
« Reply #3 on: November 29, 2013, 10:29:26 pm »
You need to edit the top line to read: c:\daphne\vldp\lair
Or you path to where you have stored the image file.
Ensure you have the Roms for lair in your Roms folder.
Save the framefile as a text file.
Also you can delete the DAT file so you can reparse the game.
« Last Edit: November 29, 2013, 10:34:13 pm by ark_ader »
Hambo3
    • insert coin
Re: Daphne problems
« Reply #4 on: December 01, 2013, 06:00:25 am »
If your on vista then it will be the same as the windows 7 issue I had. you need to register or obtain a new MSCOMCT2.OCX file.
try this theres a bunch of articles about it.
https://www.google.co.uk/#q=vista+MSCOMCT2.OCX
