Author Topic: joystick mounting ?  (Read 4565 times)
shayvidas
  • Last login:March 28, 2016, 09:18:22 pm
  • mame Fan Forever !!!
joystick mounting ?
« on: November 25, 2013, 02:48:55 pm »
hi everyone.
again like i allways say
you guys are awsome !!!
ok so i'm going to buy two of these joysticks >
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=65&products_id=383
and i'I've read like... 8 pages of the woodworking forum
but i just couldn't understand,
how do you mount toughs tjoysticks ?
i understood you can surface mount and flush mount, but what does it even mean ?
i saw allot of pictures here guys did like a groove but not the full length..
can someone maybe have a video or explain to me fully how to mount a joystick ?
if someone could it would be great !!!!!
ohh ohh
and b.t.w.
do you guys ever mounted a toggle switch ? like this >
http://www.ebay.com/itm/5Pcs-Blue-Car-Auto-Cover-LED-SPST-Toggle-Switch-Control-On-Off-12V-New-/251384944701?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a87b5d83d&vxp=mtr
is it easy enough ?
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
Re: joystick mounting ?
« Reply #1 on: November 27, 2013, 07:38:16 am »
All sorts of methods to mount.  This should give you a good start.
http://www.slagcoin.com/joystick/mounting_layering.html
Generic Eric
« Reply #2 on: November 27, 2013, 02:37:03 pm »
hi everyone.
Dawgz advice is sound.  I would also suggest doing a mock up on the same type would you plan to use on your finished project.  Use pilot holes when drilling and keep in mind that plywood may split/splinter.  Buy paintable wood filler.
Additionally, years ago I bought a mounting plate, from Groovy Game Gear I think.  You can use that as a template for your marking your holes on the wood.  You may have noticed the multi pattern one from the Arcade Paradise kickstarter.
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« Reply #3 on: November 30, 2013, 12:33:11 am »
That site was very helpful, where was it a few years ago when I got started haha.
mgb
  • North East, US
joystick mounting ?
« Reply #4 on: November 30, 2013, 01:23:21 am »
A few years ago, it was right there :)
marvin_rock
  • Last login:December 29, 2013, 06:55:51 pm
« Reply #5 on: December 22, 2013, 04:52:50 pm »
Really dumb question, I'm working on mounting everything now, how do I know which way to make sure the joystick is up?  Or is that controlled via the software once I get it all hooked.
« Reply #6 on: December 22, 2013, 05:42:43 pm »
Once you get it all hooked up.  Just ensure that one of the flat edges of the mounting bracket is parallel to the monitor.  No angled joystics!
Leo123
  • Newbie
  • Last login:August 08, 2014, 07:51:01 am
« Reply #7 on: January 01, 2014, 12:49:23 am »
can someone maybe have a video or explain to me fully how to mount a joystick ?   :badmood:
Go through  642-980 braindumps  tutorial to learn how to draw different objects from scratch using Adobe Photoshop. Become expert web designer using  ACCA  guide.
EMDB
  • Project RetroCade
« Reply #8 on: January 03, 2014, 09:21:17 am »
Example of under mount: http://forum.arcadecontrols.com/index.php/topic,130690.msg1345990.html#msg1345990
Example of top mount: http://forum.arcadecontrols.com/index.php/topic,84649.msg902127.html#msg902127
There are tons of examples in the Project Announcements section...
Ingesecition
  • Last login:October 23, 2014, 05:06:41 am
« Reply #9 on: February 05, 2014, 11:34:47 am »
Im on with making a dedicated SSF2X woody cabinet. I'm having to make a replacement control panel out of 18mm MDF topped with 4mm Plexi. Obviously any joysticks mounted underneath are going to have 22mm of clearance to get through which is leaving them short up top. Any suggestions?
mgb
  • North East, US
« Reply #10 on: February 05, 2014, 02:32:38 pm »
Top mount it in the mdf so that the artwork and plexi then cover it.
