Author Topic: Rowe Ami Nostalgia Track Startup Loud  (Read 2194 times)
EdenGarden
  • Newbie
  • Last login:November 11, 2013, 02:03:10 pm
« on: November 11, 2013, 06:47:08 am »
Hi
Recently purchased a Nostalgia and when each track starts up, the first few seconds are much louder. I can understand the use for this in a bar maybe, but in my house its a little annoying. Can it be switched off?
TIA
Stan
dddirtman
  • Last login:April 29, 2014, 04:38:42 pm
  • juke tech
Re: Rowe Ami Nostalgia Track Startup Loud
« Reply #1 on: November 26, 2013, 06:44:55 pm »
1.
check the avc setting on your amp(if the amp has this switch),usually located near the (mono/stereo)switch.
2.
check the wiring on the volume control(internal or external)
ed12
« Reply #2 on: November 26, 2013, 09:24:13 pm »
just as posted
avc is not kicking in right
it should start low and go up from there
your avc may need to be rebuilt >new caps as a rule<
ed
