Author Topic: my new cab in the italy zone :)  (Read 4227 times)
paolinux78
  • Last login:October 04, 2021, 06:00:18 pm
« on: November 05, 2013, 05:00:13 am »
Hello everyone, after the experience last year with the construction of a bartop that helped me to do some practice with wood and electrical connections, are now grappling with a real "upright." Loosely inspired by the various cab 80s, by Taito to Nintendo and also from the generic cab that were at the bar ...
I left 6mq of plywood 3/4in taken in woodworking in the house, I bought a dozen L-metal joints a lot of small screws, 2 fixed and 2 swivel wheels with brakes, each 110lbs capacity, is high with wheels including 69in , 25in wide and 30in deep, for questoni of practicality and "view" waive my dear old CRT monitor (which unfortunately tires me so much the view) and will opt for a less quality but more restful LCD. The design is classic here is a picture of the profile cut with an electric saw and a little bit with the jigsaw:
and here it is partially assembled:
obviously also insert the coin, I will keep you updated with more photos! :)
paolinux78
Re: my new cab in the italy zone :)
« Reply #1 on: November 06, 2013, 07:37:41 am »
Here I am with some updating, I started working on the bridge, also built with plywood 3/4, made me swear a bit to create the home of 2 joysticks, however at the end everything went perfect, now a bit of putty and then when you get the PVC adhesive mounts, here is a bit of photos:
jeremypps
  • Last login:August 11, 2014, 09:42:42 am
« Reply #2 on: November 07, 2013, 03:58:28 am »
Hi congratulations for your work, I'm planning to build a full size cab as well but I don't know when I'll have enough spare time ....
Is it really plywood ? from the pictures it seems pine wood.
how did you put all together, screws, glue, etc ?
for the pvc, did you draw the sides yourself ? and where did you have them printed ?
thanks and keep us informed
è veramente compensato ? dalle foto sembra pino o abete o simili
hai usato colla e squadrette a L o solo le squadrette ?
hai fatto tu i disegni per gli adesivi o li hai presi da qualche parte ?
dove li fai stampare ? pixartprinting ?
grazie, ciao
paolinux78
« Reply #3 on: November 07, 2013, 05:48:18 pm »
hello, is up for it! pvc print from pixartprinting I do and I'll do a fantasy style space invaders!
I mounted the monitor:
ark_ader
  • I glow in the dark.
« Reply #4 on: November 08, 2013, 12:42:17 am »
Looks awesome.  Hope you stain it and make it look like a proper piece of furniture.
paolinux78
« Reply #5 on: November 08, 2013, 07:13:44 am »
thanks!
come the prints, so here is a little taste of the marquee, the kind that will put coin in the dashboard and in the moneybox area:
paolinux78
« Reply #6 on: November 09, 2013, 02:10:37 pm »
work is progressing and make no mistake as my cabinet as well as being arcade will also jukebox I did get an active speaker as well 400W  :afro: ;D
paolinux78
« Reply #7 on: November 10, 2013, 08:59:03 am »
Here I am with some news, I finished the dashboard here are 2 photos:
before the assembly of the keys:
and after assembly:
« Last Edit: November 10, 2013, 09:01:03 am by paolinux78 »
paolinux78
« Reply #8 on: November 12, 2013, 06:23:59 am »
today I finished the lower front where there is a coin
empardopo
  • Last login:Yesterday at 03:10:00 pm
    • My personal forum
« Reply #9 on: November 12, 2013, 11:56:10 am »
Very good job!
Enviado desde mi GT-N7100 usando Tapatalk 2
paolinux78
« Reply #10 on: November 12, 2013, 05:04:23 pm »
here is with the control panel mounted:
paolinux78
« Reply #11 on: November 14, 2013, 06:35:35 pm »
work is progressing and I'm almost finished, lacking only the bezel and the door behind:
jongunz
  • Last login:July 22, 2015, 11:57:42 pm
« Reply #12 on: November 17, 2013, 02:08:41 am »
Holy hell... that's a huge speaker.  Build looks good.
paolinux78
« Reply #13 on: November 17, 2013, 03:35:43 pm »
finish!!
mgb
  • Last login:January 06, 2025, 09:39:00 pm
  • North East, US
« Reply #14 on: November 19, 2013, 12:51:03 am »
Excellent.  :applaud:
