Author Topic: K7300 Monitor problem?  (Read 8021 times)
Z0MBIE
  • Last login:March 04, 2014, 06:13:03 pm
  • Dead and loving it!
« on: October 17, 2013, 02:04:16 pm »
Got in a Wrestlemainia game in and when turned on I can hear the ping from the speaker and see LEDs on the board light but nothing what so ever on the screen at any time. I have 120v to the board for the screen and the fuse is ok. I do not see any glow in the neck of the tube and made sure the board on the neck was pushed in all the way, all the caps also look physically good to. But I also do not hear anything for when a coin drops or hitting any play buttons. Any ideas?
« Last Edit: November 01, 2013, 04:53:31 pm by Z0MBIE »
grantspain
Re: Orion Monitor problem?
« Reply #1 on: October 18, 2013, 08:48:54 pm »
never seen an orion monitor,seen loads of orion tubes though
whats the actual chassis mate?
photo would help
Z0MBIE
« Reply #2 on: October 21, 2013, 04:46:50 pm »
I think you're right that it's just the tube but here is a pic of the board.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: October 21, 2013, 05:39:55 pm »
Z0MBIE
« Reply #4 on: October 21, 2013, 05:42:45 pm »
Thanks Ken, at least I know what it is now.
Z0MBIE
« Reply #5 on: October 23, 2013, 02:31:54 pm »
Anything common on these? all caps test good.
grantspain
« Reply #6 on: October 24, 2013, 05:50:02 pm »
all caps tested with a cap tester or just look ok?
Z0MBIE
« Reply #7 on: October 24, 2013, 05:54:07 pm »
Tested.
grantspain
« Reply #8 on: October 25, 2013, 03:48:02 pm »
ok then isolate the B+ and add a dummy load then check the b+ voltage
Z0MBIE
« Reply #9 on: October 25, 2013, 03:51:38 pm »
LOL I'm a total n00b and do not know what that means.
Z0MBIE
Re: K7300 Monitor problem?
« Reply #10 on: November 01, 2013, 04:54:35 pm »
Ok, I went ahead and installed a new cap kit anyway and still get the same results.
grantspain
« Reply #11 on: November 01, 2013, 08:18:03 pm »
i would like to help more but being a novice you will either end up blowing the crap out of the chassis or giving yourself a nasty shock
Z0MBIE
« Reply #12 on: November 01, 2013, 09:03:02 pm »
Not quite that dumb.
Z0MBIE
« Reply #13 on: November 14, 2013, 04:04:52 pm »
ok besides the cap kit I replaced the HOT Transistor then I read the common problem for these is 812 resistor and the Q801 transistor so I replaced those also and still no neck glow or picture. :banghead:
Z0MBIE
« Reply #14 on: November 19, 2013, 05:36:30 pm »
Update- I had someone else tell me to replace the chip that had LA7851 on it so I took that chip from a junk board and put it in and low and behold I had a picture so I grabbed the remote board to adjust the picture and after a few minutes all of a sudden screen went black again WTF? so if that chip went out again I wonder what caused it?
Z0MBIE
« Reply #15 on: January 05, 2014, 02:46:39 pm »
Anybody??? I do hear the static charge when turning it on but no picture. :angry:
emich
  • Last login:January 04, 2020, 11:32:29 pm
« Reply #16 on: January 03, 2020, 07:06:09 am »
Hey, hope you read this but I'm currently trying to fix this board right now and I was hoping if you'd be able to post a closer look at the resistors on the bottom left quadrant. The board I have now is covered in rust so I am unable to see the color of the band on them.
Thank you!
P.S have you been able to fix your issue?
behrmr
  • Last login:April 23, 2021, 09:17:13 am
« Reply #17 on: January 03, 2020, 10:49:48 am »
Thank you!
The schematic will be helpful for what you want https://www.arcade-museum.com/manuals-monitors/Wells%20Gardner%2013k7301.pdf
Ken's repair guide is also good https://www.arcade-museum.com/manuals-monitors/Wells-Gardner_K7300_series_repair.pdf
emich
« Reply #18 on: January 04, 2020, 12:39:58 pm »
Thank you! I'll look into it.
What did you do to fix your issue?
