Author Topic: advice on polycarbonate (adding cp cover later)  (Read 716 times)
« on: October 11, 2013, 07:38:26 pm »
Are there any ingenious ways of ensuring your cp overlay matches your panel f you didn't cut them together or have a template?
AlienInferno
  • Last login:June 24, 2025, 12:14:27 am
Re: advice on polycarbonate (adding cp cover later)
« Reply #1 on: October 11, 2013, 11:03:19 pm »
Do you mean the artwork or the plexi top?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
« Reply #2 on: October 11, 2013, 11:46:56 pm »
Plexi top. I'm thinking trying to make some kind of stencil.
« Last Edit: October 12, 2013, 08:39:44 am by harveybirdman »
AlienInferno
« Reply #3 on: October 11, 2013, 11:57:57 pm »
If you have a router you can use a flush trim bit to make the two match.  You would have to be able to remove the CPO top though.  I even used a router to cut out the button holes. (I sandwhiched the plexi between my existing panel and a piece of scrap to cut out the holes).
Also something else that might work is using a piece of poster board or other heavy paper type product.  Remove the controls from your panel, lay the poster board on top, tape it down in a few spots to be secure, and use a hobby knife / razor blade to carefully cut out the holes for your controls and the panel outline into the poster board. You can then use the poster board as a template for your plexi.
« Reply #4 on: October 12, 2013, 08:43:20 am »
Thanks for the tips, I think I'm going to end up putting a drop cord underneath and shine light up through the panel through sheets from slagcoin.  Once i have a button hole centered over the hole in the CP I'll mark the drill hole on my Lexan (assuming I can see the template through the protective covering.  It might work......
