Author Topic: joychoose issue  (Read 1582 times)
tony.silveira
  • Last login:September 27, 2024, 03:04:35 pm
    • my baby
joychoose issue
« on: September 17, 2013, 09:30:32 pm »
hi all,
FINALLY getting around to adding switching 4/8 way sticks but am running into a small issue.  FYI, i am using ultimarc's excellent servo kit (installed on a U360).
first up, andy's software JoyTray works just fine.  i can test and select 8 0or 4 way and the arm spins in the appropriate direction.
same thing with the joychoose mala plug in.   when i load it from within mall and test, all good.
now i get to selecting a game.  first up, donkey kong.  the servo spins when starting and exiting the game but it spins in the SAME direction.  so basically, the servo is stuck trying to spin but it can't.
i have mala pointing to the contyrols.ini file, i'm not sure what's going on.
any help?
  • Last login:January 26, 2026, 08:08:49 am
Re: joychoose issue
« Reply #1 on: September 17, 2013, 10:44:40 pm »
See "When game ends" section at bottom.  Set to Don't Use.
tony.silveira
    • my baby
Re: joychoose issue
« Reply #2 on: September 17, 2013, 11:00:21 pm »
i just tried this and it still behaves the same.  in fact, it was already set to "don't use" but i tried switching to 8 way, quitting, restarting, same thing.  set it back to "don't use", quit, restart, same thing.
any other suggestions?  can't wait to get this up and running!
  • Last login:January 25, 2026, 10:26:13 pm
Re: joychoose issue
« Reply #3 on: September 18, 2013, 07:51:21 am »
What are your settings in joychoose?
(Program called for 8 way and 4 way and arguments, if any)
Can you post a screen shot of the joychoose setup?
« Last Edit: September 18, 2013, 07:53:39 am by DaOld Man »
Re: joychoose issue
« Reply #4 on: September 18, 2013, 11:12:55 pm »
ControlChoose emailed to you. See if you have the same issues with it.
