Author Topic: Probably a very easy NOOB question here about 4 way joystick  (Read 1104 times)
braidsrx
  • Last login:December 22, 2014, 07:02:39 am
« on: September 17, 2013, 01:37:52 pm »
Hello experts!!  I recently bought a wiring kit and joystick from ultimarc.com.  I chose a stick that could be restricted to true 4 way use because I am using it to rebuild a CP for Q*bert.  My question is, the stick has a moveable restrictor plate that can be tightened with screws... but I'm unsure which position locks the corners out ( leaving only up, dn, L, R able to hit switches).  Can anyone advise?  Sorry if this is covered elsewhere.  And any advice on getting the angles perfect to mount the stick correctly ? ( a 45 degree turn to allow for authentic Q*bert moves... :)    Thank you all in advance !!!
Re: Probably a very easy NOOB question here about 4 way joystick
« Reply #1 on: September 17, 2013, 01:42:55 pm »
If it is the type of restrictor plate I am thinking, the plate will a have diamond shaped hole when restricting to 4 ways.
dgame
  • I am no Jedi
« Reply #2 on: September 17, 2013, 01:44:29 pm »
You want the restrictor to be in a diamond shape where each direction is a point on the diamond.
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
« Reply #3 on: September 18, 2013, 05:06:29 am »
You want the restrictor plate rotated to diamond shape relative to the square/rectangle joystick base. Then you want the joystick at 45degress in your panel.
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
EMDB
  • Project RetroCade
« Reply #4 on: September 18, 2013, 05:40:28 am »
Or use their UltraStick360 which you can configure in software to have 4-way diagonal directions for Q-bert (and 2/4/8 way for all other games as a bonus).
