Hi guys!
Back from holiday in Bibione, Italy -
here in lovely Klagenfurt, Austria - absolutely no summer left - time to finish what needs 2 be ..
My setup is a
Midway MK Cabinet with a WG 25k7197
ATI 1200
WinXP
Soft15k
VMMaker 1.3c + Calamity Catalyst
Groovymame/Ume 0.149.014b
Thx 2 Calamity and Sledge
my win is bootin up nicely on my arcade monitor and Vmmaker produces loads of nice modelines useable in ArcadeOSD and systemregistry....
Now lets go2work....
Target: Pixelperfect Groovymame almost any game
Problem: As flawlessly Vmmaker seems 2 work, Groovymame doesnt...
my
interlace 0
is completely ignored, and most of the games are started in an interlacéd res, none starts with its native resolution....
Is there a mame.ini template with the necessary options for Groovymame?
Please check my /ini/mame.ini :
Thx,
R.
# CORE CONFIGURATION OPTIONS
readconfig 1
writeconfig 0
# GROOVYMAME
crt_range0 15650-16200, 49.5-65, 2.000, 4.700, 8.000, 0.064, 0.192, 1.024, 0, 0, 192, 288, 448, 576
interlace 0
# CORE SEARCH PATH OPTIONS
rompath roms
hashpath hash
samplepath samples
artpath artwork
ctrlrpath ctrlr
inipath ini
fontpath .
cheatpath cheat
crosshairpath crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory cfg
nvram_directory nvram
memcard_directory memcard
input_directory inp
state_directory sta
snapshot_directory snap
diff_directory diff
comment_directory comments
# CORE STATE/PLAYBACK OPTIONS
state
autosave 0
playback
record
mngwrite
aviwrite
wavwrite
snapname %g/%i
snapsize auto
snapview internal
statename %g
burnin 0
# CORE PERFORMANCE OPTIONS
autoframeskip 0
frameskip 0
seconds_to_run 0
throttle 0
sleep 1
speed 1.0
refreshspeed 0
# CORE ROTATION OPTIONS
rotate 1
ror 0
rol 0
autoror 0
autorol 0
flipx 0
flipy 0
# CORE ARTWORK OPTIONS
artwork_crop 0
use_backdrops 1
use_overlays 1
use_bezels 0
use_cpanels 1
use_marquees 1
# CORE SCREEN OPTIONS
brightness 1.0
contrast 1.0
gamma 1.0
pause_brightness 0.65
effect none
dotclockmin 8.0
# CORE VECTOR OPTIONS
antialias 1
beam 1.0
flicker 0
# CORE SOUND OPTIONS
sound 1
samplerate 48000
samples 1
volume 0
# CORE INPUT OPTIONS
coin_lockout 1
ctrlr
mouse 0
joystick 1
lightgun 0
multikeyboard 0
multimouse 0
steadykey 0
ui_active 0
offscreen_reload 0
joystick_map auto
joystick_deadzone 0.3
joystick_saturation 0.85
natural 0
joystick_contradictory 0
coin_impulse 0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device keyboard
adstick_device keyboard
pedal_device keyboard
dial_device keyboard
trackball_device keyboard
lightgun_device keyboard
positional_device keyboard
mouse_device mouse
# CORE DEBUGGING OPTIONS
log 0
verbose 0
update_in_pause 0
debug 0
debugscript
debug_internal 0
# CORE MISC OPTIONS
bios
cheat 0
skip_gameinfo 0
uifont default
ramsize
confirm_quit 0
ui_mouse 0
autoboot_command
autoboot_delay 2
autoboot_script
# WINDOWS DEBUGGING OPTIONS
oslog 0
watchdog 0
debugger_font "Lucida Console"
debugger_font_size 9
# WINDOWS PERFORMANCE OPTIONS
priority 0
multithreading 1
numprocessors auto
profile 0
bench 0
# WINDOWS VIDEO OPTIONS
video ddraw
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
waitvsync 1
syncrefresh 1
menu 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 0
# DIRECT3D-SPECIFIC OPTIONS
filter 1
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable 0
hlslpath hlsl
hlsl_ini_read 0
hlsl_ini_write 0
hlslini %g
hlsl_prescale_x 0
hlsl_prescale_y 0
hlsl_preset -1
hlsl_write
hlsl_snap_width 2048
hlsl_snap_height 1536
shadow_mask_alpha 0.0
shadow_mask_x_count 320
shadow_mask_y_count 240
shadow_mask_usize 0.09375
shadow_mask_vsize 0.109375
curvature 0.03
pincushion 0.03
scanline_alpha 1.0
scanline_size 1.0
scanline_height 1.0
scanline_bright_scale 1.0
scanline_bright_offset 0.0
scanline_jitter 0.0
defocus 0.0,0.0
converge_x 0.3,0.0,-0.3
converge_y 0.0,0.3,-0.3
radial_converge_x 0.0,0.0,0.0
radial_converge_y 0.0,0.0,0.0
red_ratio 1.0,0.0,0.0
grn_ratio 0.0,1.0,0.0
blu_ratio 0.0,0.0,1.0
saturation 1.4
offset 0.0,0.0,0.0
scale 0.95,0.95,0.95
power 0.8,0.8,0.8
floor 0.05,0.05,0.05
phosphor_life 0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable 0
yiq_cc 3.59754545
yiq_a 0.5
yiq_b 0.5
yiq_o 0.0
yiq_p 1.0
yiq_n 1.0
yiq_y 6.0
yiq_i 1.2
yiq_q 0.6
yiq_scan_time 52.6
yiq_phase_count 2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale 0.8
vector_length_ratio 500.0
# BLOOM POST-PROCESSING OPTIONS
vector_bloom_scale 0.3
raster_bloom_scale 0.225
bloom_lvl0_weight 1.0
bloom_lvl1_weight 0.21
bloom_lvl2_weight 0.19
bloom_lvl3_weight 0.17
bloom_lvl4_weight 0.15
bloom_lvl5_weight 0.14
bloom_lvl6_weight 0.13
bloom_lvl7_weight 0.12
bloom_lvl8_weight 0.11
bloom_lvl9_weight 0.10
bloom_lvl10_weight 0.09
# PER-WINDOW VIDEO OPTIONS
screen auto
aspect auto
resolution auto
view auto
screen0 \\.\DISPLAY4
aspect0 auto
resolution0 auto
view0 auto
screen1 auto
aspect1 auto
resolution1 auto
view1 auto
screen2 auto
aspect2 auto
resolution2 auto
view2 auto
screen3 auto
aspect3 auto
resolution3 auto
view3 auto
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 1
full_screen_brightness 1.0
full_screen_contrast 1.0
full_screen_gamma 1.0
# WINDOWS SOUND OPTIONS
audio_latency 2
# INPUT DEVICE OPTIONS
dual_lightgun 0
