Author Topic: Wanted: Fix-it Felix Jr cabinet  (Read 1126 times)
Nic-93
  • Last login:August 10, 2017, 09:40:14 pm
  • I hope this forum will help me on needed things.
« on: August 29, 2013, 05:40:59 pm »
Im not sure if this would be the right place, but it is sort of wanted.
moveing to a more fitting forum post is welcome.
im looking for someone who i could commission for getting a fix it felix cabinet made,
are anyone interested?, it shall have the traditional arcade monitor and shall have the normal controller layout as on a donkey kong cabinet with 1 and 2 player butten, and functional coin door, and it shall be in the traditional nintendo cabinet with functioning marguee, and its plywood i think it where called, i can fit in the computer myself, i just want the monitor and cabinet done and with a j-pack  for the monitor and controller and coindoor.
I live in denmark.
« Last Edit: August 31, 2013, 02:54:00 pm by Nic-93 »
Nic-93
Re: Wanted: Fix-it Felix Jr cabinet
« Reply #1 on: August 31, 2013, 01:58:40 pm »
are anyone interested?, it shall have the traditional arcade monitor and shall have the normal controller layout as on a donkey kong cabinet with 1 and 2 player butten, and functional coin door, and it shall be in the traditional nintendo cabinet with functioning marguee, and its plywood i think it where called, i can fit in the computer myself, i just want the monitor and cabinet done and with a j-pack  for the monitor and controller and coindoor and side art.
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #2 on: August 31, 2013, 02:12:20 pm »
Where you based?
WWW.Xtremepinball.com
Pm me for custom cnc needs...
Nic-93
« Reply #3 on: August 31, 2013, 02:53:33 pm »
Where you based?
i frorgotted to add that, im from denmark,
macattack
« Reply #4 on: August 31, 2013, 04:39:51 pm »
Ahh, ok bit far then. Shipping would not be wise. Good luck.
  • Last login:May 19, 2025, 11:21:11 am
« Reply #5 on: August 31, 2013, 04:59:59 pm »
Hey Nic-93,
I received your PM. I'm in Canada, and I've been quoted shipping costs around $200 for a standard cabinet inside Canada, so it would be cost prohibitive to ship to Denmark, I'd wager. I'm pretty sure you'll want someone who is closer, probably in the U.K.
Now, what I might recommend is commissioning someone to provide you with a DXF drawing file, which you could then give to a local CNC shop, and have them produce the carved item for you. If you're interested in that, PM me again, and I can quote you a price on the cabinet plans.
Cheers!
