Author Topic: ROWE-AMI r 1-4  (Read 1713 times)
ncassway
  • Last login:September 11, 2013, 06:40:34 pm
  • rowe-ami r1-4
ROWE-AMI r 1-4
« on: August 26, 2013, 05:16:31 pm »
Hi
I have a rowe-ami r 1-4, for the most part it works really well, but the lower half of the keypad does not work, I cannot use the numbers 6, 7 8, 9, 0.
Could this be an issue with the CCC, I looked at the board and noted some significant corrosion from the battery.
Thanks in advance for any advice.
Nick
Philadelphia, PA USA
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: ROWE-AMI r 1-4
« Reply #1 on: August 27, 2013, 07:04:24 am »
Hello Nick,
Welcome to the forum.
Have you checked the Pricing board for dry joints (cold joints USA) on the top and bottom connectors.
The CCC could be the issue and other than checking dry joints to the connection pins the CCC needs to be checked by a Rowe Ami engineer, I suggest that you send your board to Bruce Wentworth at AB leisure being as he is on your side of the pond.
Regards
Alan
Alan Hood
ami-man
UK
