Author Topic: First Cab Project 45% complete. PROBLEMS! In need of some help!  (Read 11308 times)
ArcticCowboy
  • Last login:July 05, 2015, 06:26:04 pm
  • I want to build my own arcade!
Started working on my first cabinet. I'm going in blind, which probably isn't the best idea, but I've never been good for god ideas. Got a 24" tv from the local salvage store, uncased and mounted it. Build the sides and supports for it so far.
I could really use suggestions from people, or someone letting me know if I'm doing anything drastically wrong befre I do a ton of work on this thing  :lol
« Last Edit: November 09, 2013, 04:40:47 pm by ArcticCowboy »
ArcticCowboy
Re: First Cab Project
« Reply #1 on: August 23, 2013, 04:47:50 pm »
Also added a panel for mounting computer hardware
Buick455
  • Last login:April 03, 2024, 03:24:29 pm
  • I MUSTA WRECKED IT!
« Reply #2 on: August 23, 2013, 06:26:48 pm »
looks like a good start.
I have yet to build my cabinet (been using a 2x4 frame mock up forever) but I think you might want to radius those corners if you plan on installing t-molding. From what I have read it doesnt like sharp corners..
ArcticCowboy
« Reply #3 on: August 23, 2013, 06:55:25 pm »
Huh, hadn't thought of that. I'm looking into it now. As long as its not too costly, I may have to invest in a tool to do that with. Currently the only power tools I have to work with are a circular saw and a drill (bought them for this project.
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
First Cab Project
« Reply #4 on: August 23, 2013, 07:15:07 pm »
A router will be your best friend during the build.
Don't get a cheap model though. It will help you with rounding the edges and getting the groove cut for t-moulding. It will also help with laminate if you go that way.
sabreerbasAlpha
  • Remember those big 10ps?
« Reply #5 on: August 23, 2013, 07:45:46 pm »
+1
The router is an essential tool in building an Arcade cab. Well it is if you want it as a good as im sure you do. Right now you seem to have made a good start my friend. But are you sure both sides are an exact copy of each other?. Take a look at any of the builds here and all of them will show you the builders using a flush cutter to copy both sides and get them nice round edges for the T molding. If your not fussed with T molding or it being bang on both sides then carry on. But ask yourself this question. Are you going to be a 100% happy when its finished or are you going to be like I wish I had done this and that. Like Voodoo said, Get yourself a good router, Don't buy a cheap one. I don't expect you to pay 300 pound like I did but you can pick one up from around 80-90 pounds which will be a good solid tool to use. Watch some videos on YouTube about using a router and give it a go. You will thank us in the end. And your build will be so much better for it. Don't forget to ask for help also if you need. There are some super talented people on these boards with years of experience in building and using these tools. Remember were here to help. Good luck mate.
ArcticCowboy
« Reply #6 on: August 23, 2013, 08:44:50 pm »
Thanks for the advice Voodoo and Alpha,
Just looked at some routers (I love having a home depot 5 min away from my house), and I think this id definitely going to be the next power tool I invest in.
However, what I saw was a little bit more expensive than what I can afford right now. I'll definitely pick one up though, just have to find the right price.
It'll happen before I paint the thing though.
as far as making exact copies of the sides, I cut out one side out based on a build I found on the forum, then outlined the cut-out on the other piece of particleboard. The cuts were cut with a circular saw, following the outline. Not exact, but not too bad considering its my first try. I'm happy with them. With some t molding it'll look good, I think.
ArcticCowboy
« Reply #7 on: August 24, 2013, 01:29:08 am »
Good news! Got a used router on eBay for $26. Should be here in a few days
a1pharm
« Reply #8 on: September 02, 2013, 12:28:22 pm »
Have you made any more progress yet?
ArcticCowboy
« Reply #9 on: September 04, 2013, 08:43:52 am »
Yeah! Buttons for the cp came the other day. Got the pieces all cut and put together. I'll post pics later today
ArcticCowboy
« Reply #10 on: September 04, 2013, 08:45:21 am »
Btw. Where is the best place to get a t molding router bit? I've been lookin around and haven't found anything
a1pharm
« Reply #11 on: September 04, 2013, 08:49:40 am »
www.groovygamegear.com has them for $20, while amazon.com has them for $19.  You might be able to find one cheaper, but not by too much.
ArcticCowboy
« Reply #12 on: September 04, 2013, 11:21:02 am »
finally got some pics loaded on my computer! Theses are older pics, but it'll show the steps I took to get where I am today.
Bought a 24 inch CRT tv from a salvage shop for $20, took the case off and mounted it in a wood frame that will go into the actual cabinet.
I needed the TV to turn on when it was plugged in (the power button is not going to be in an accessible  location) and I was at home depot looking at soldering kits. Wound up meeting a guy who worked there who offered to come over when he got off to show me how to solder with his own kit. So instead of spending $30 on a soldering kit, I spent a couple bucks on beer for us and he spent 5 min soldering the board for me  :cheers:  :applaud:
ArcticCowboy
« Reply #13 on: September 04, 2013, 11:27:26 am »
Got started on the control panel. The player 1, player two and the red and blue buttons arrived in the mail. Still waiting on the joysticks, but I had to get started on it. Found a scale print of an 8 button layout (I'm doing 6, so a little scissor work fixed that up) I had the board cut out, so all I needed was a few quick measurements for borders (which I got wrong.... three times), and then it was just deciding on good placement for the two prints that I had made. Twelve 1 1/8" holes later and I had a decent looking CP!
ArcticCowboy
« Reply #14 on: September 04, 2013, 11:28:39 am »
Just a couple more pics of the CP  :blah:
ArcticCowboy
« Reply #15 on: September 04, 2013, 11:32:51 am »
Alright, so I decided that the front of the CP looks really clunky and just pretty freaking bad. I took off the front part of the CP and replaced the 1/2 Inch boards with some 1/8 flexible stuff (can't remember the name of the board). The bend is pretty hard in some places, but I'm pretty sure it should hold.
Also, I learned that a jigsaw is a terrible tool to make staight, smooth cuts. Especially when you don't have saw-horses or a work table
ArcticCowboy
« Reply #16 on: September 04, 2013, 11:40:09 am »
Finally got the screen in! I had to wait till I could find two sober guys to help hold it in place while I drilled the holes. (In a college town, two sober guys are rather hard to come by.) The frame I put the TV in looks like a giant POS, but hopefully once I put a panel over it and cover up those edges, it'll look alot better. Not sure if I should make a bezel or if I can just get away with making a 24 inch hole in some 1/8" board and then putting a sheet of plexiglass over that. I don't know, but I'm getting more and more pumped to get this thing operational.
Also, got an old computer from a shady guy in downtown Toledo. (I checked, it works fine.) The only big pieces of equipment I need to get this thing operational now is a keyboard encoder, some wiring for the buttons and a video card with composite out. Not sure where the best place to look for those is. Wiring at a Home Depot or Lowes, obviously. But I've looked on ebay for an encoder and they look to be about $100 there. Still need to check amazon.
TheChairmanH2K
  • Last login:October 08, 2013, 12:53:17 pm
« Reply #17 on: September 04, 2013, 11:56:48 am »
go here http://www.ultimarc.com/store/section.php?xSec=2&xPage=1&jssCart=912fd647f01be90bbed854762ea64135 get an Ipac 2 or 4 based on your needs.  there are also many many other encoders out there such as Kade and Lono that i dont have any experience with but others on the forum do.  no need to spend $100.
  • Last login:Today at 05:33:34 am
« Reply #18 on: September 04, 2013, 12:07:57 pm »
Check out the KADE, I-Pac, or KeyWiz.
For the wiring, get stranded 22 or 24 AWG (NOT SOLID) for use with crimps.
You can also get pre-crimped wires with some of the encoders or from Paradise Arcade Shop. (The daisy chains and 16 wire rainbow packs are my personal favorites)
mcseforsale
  • Creepy Mario Dude
« Reply #19 on: September 04, 2013, 12:13:31 pm »
Also, don't count out good pawn shops for tools.  Many of them will give you a warrantee.  I've been beating on my router for years and I got a ~$200 router for 20 bux.
AJ
ArcticCowboy
« Reply #20 on: September 04, 2013, 12:22:06 pm »
didn't post a pic of it, but I got an older router from eBay for $25. Seems to work well. I just need the bit to do the T-Molding
jmike
« Reply #21 on: September 04, 2013, 12:27:22 pm »
Great job so far ArcticCowboy.
       can you post some pictures on how you mounted the TV to the cab? I have a similar TV but thought it would be too heavy to mount like that.
Keep up the good work
a1pharm
« Reply #22 on: September 04, 2013, 12:36:08 pm »
Get the Keywiz from www.groovygamegear.com
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=76_80&products_id=303
It's $36 and you can also by pre-crimped wiring with it for cheap (get 20 or 30 of the crimped wires: its an option with the keywiz)
I think the 1/8" bezel with a 24" diag hole will work fine at hiding that hideous mount, especially if you plan to use a plexi overlay.  The 1/8" wood will ensure the plexi doesn't rest right up against the tube.  After you cut the 24" hole in the 1/8" board, use a 45deg or a rounded router bit to smooth over the sharp edge of the hole, it will give the bezel a "matted" look, which is pro.
Good work so far, enjoy the build.
Cheers!
ArcticCowboy
« Reply #23 on: September 04, 2013, 01:39:22 pm »
Here ya go, jmike
to start with I took the tv and removed the case, unplugged the speakers (don't worry about keeping these in good condition, unless you plan on using them on the cab. I'm not planning on using them so I just threw them out.)
The actual screen is held in with screws drilled into a metal attachment in each corner of the screen. I simply made a frame out of 2x4s and then used the same screws that were in the plastic case to drill into the wood to hold the screen in my frame. The frame is in a picture I already posted, but the screws holding it in look like this:
From there I planned out how I was going to put the frame into the cabinet. I'll be honest with you, but I measured wrong about 4 times before I finally got to where I could put the screen in and still have enough space for the cover plate etc. It looks like crap and its a pain in the ass but on each side of the cabinet I did this:
I pre-drilled the holes and got two guys to hold the screen in place while I screwed it in. (Predrill the holes, otherwise your helpers are going to be whining about how heavy it is while you try and get a screw started.  ;D ) Four screws on top, four on the bottom and two down the sides, repeat on either side and it feels quite solid. MAKE SURE YOUR SCREWS ARE LONG ENOUGH TO MAKE THE TV SECURE, BUT NOT LONG ENOUGH THAT THEY GO INTO THE SCREEN! I came really close to doing that. Luckily I realized what I was doing before I started drilling.
After that you should be good! The back of my mounted screen looks like This:
I know the frame looks like crap, but I think it'll hold and I'll be covering up all the nasty looking spots.
Hope that helps! Keep in mind, this is my first cab, and I am by no means an expert on this.
ArcticCowboy
« Reply #24 on: September 04, 2013, 01:41:01 pm »
Oh Crap! I missed a screw!
  • Last login:February 09, 2026, 11:56:07 am
« Reply #25 on: September 04, 2013, 04:17:40 pm »
Before you go any further, take the monitor out and cut the T-Molding slots.
ArcticCowboy
« Reply #26 on: September 04, 2013, 05:46:09 pm »
Is there a reason why its a bad idea to cut tmolding slots with the monitor in? That monitor was a pain to get in the first time
a1pharm
« Reply #27 on: September 04, 2013, 06:08:56 pm »
As long as it's rigid, you don't need to remove it.  Flipping the cab around will be easier with it removed (you'll need to do this when cutting your slots), but it's not absolutely necessary.  I do agree to not add anything else to the cab without first cutting your slots.  I always cut my slots prior to attaching anything to the sides, simply because that is the easiest point to do it.
ArcticCowboy
« Reply #28 on: September 04, 2013, 08:20:07 pm »
Yeah, its difficult to tip, but I had to do it earlier today to reattach a wheel. So it's doable. I'll probably just cover up the microboard of the TV to keep sawdust off it
« Reply #29 on: September 04, 2013, 08:24:51 pm »
The MDF dust gets everywhere.
Cover the monitor with plastic+tape, then add a layer of newspaper+tape. (plastic holds a static charge that attracts the dust, newspaper doesn't)
ArcticCowboy
« Reply #30 on: September 07, 2013, 09:25:44 pm »
Does anyone know where to get a good 21"x16" bezel? I've tried making my own and it looks like crap.
« Reply #31 on: September 08, 2013, 12:23:52 am »
GOG can do custom sizes for a variety of classic bezels here or print your custom artwork here.
ArcticCowboy
« Reply #32 on: September 12, 2013, 11:36:47 pm »
The wiring has begun!
Got the ipac in the mail the other day, along with a video card with composite out and a tmolding router bit.
Unfortunately the drivers for the video card only seem to work on wondows XP and not vista.... weird. So I'm thinking I need to replace my operating system if I can't find a driver that works.
So yeah, I should have everything I need to make the cabinet operational. I just need to work on aesthetics after that. (The cabinet looks like a piece of crap sitting in my living room. But there's definitely progress!
ArcticCowboy
« Reply #33 on: September 12, 2013, 11:39:50 pm »
Also, heres a pic of the computer I got. I took everything out of the case and just installed the motherboard, power supply and hard drive. I've extended the power button wires, and soldered a couple wires to the TV so I can put a couple buttons on top of the cabinet. I havent found out how to hook both up to one switch, but I can get a second switch if I need to.
ArcticCowboy
« Reply #34 on: September 30, 2013, 04:18:41 pm »
Alright. I'm stuck and I'm not sure where to go from here. I've posted a video on what the problem is and I'm hoping someone can help me. Basically when the computer is connected to the TV it comes in black and white and the picture is flashing up and down vertically. (Check out the video to actually see it) If anyone has any idea whats going on, or how I can fix it, I would be greatly appreciated. Thanks!
jdbailey1206
« Reply #35 on: September 30, 2013, 07:16:35 pm »
I would also get a regular computer monitor to see correctly and change your refresh rate.  If I remember correctly the tv has a lower refresh rate while a computer monitor standard setting should be set at 65 mhz.
ArcticCowboy
« Reply #36 on: September 30, 2013, 07:24:56 pm »
Tried that. there are a number of refresh rate options listed on my computer. 60, 72, 75, 80, 85, 100, 120. (I think thats all of them). Anything above 80 and the computer monitor would shut off and wouldn't work. None of the refresh rates would make the TV display a steady screen
CaptainMarvel
  • Last login:May 03, 2020, 04:49:55 pm
« Reply #37 on: October 01, 2013, 01:33:46 pm »
Very much enjoying watching your progress thus far ... keep up the great work !!!
Out of curiosity,  what is the reason for mounting your computer parts onto the peg board rather than keeping them within the case/chassis ??
TOM
Understanding that you may not see success instantly, but that all your good decisions add up to a cumulative success over time is what separates those who "get there" and those who don't. Every day you either get further away from your goals, or closer to them . . . Its up to YOU."
ArcticCowboy
« Reply #38 on: October 02, 2013, 08:56:18 am »
Honestly I'm trying to cut down on weight. Also it'll be easier for me to access the board in case I need to upgrade or make any changes to the computer. In hindsight, I'll probably keep the computer in the case if I wind up making another cabinet. But it seemed like a good idea at the time.
« Reply #39 on: October 02, 2013, 09:06:23 am »
Kudos to you for decasing. I like doing it that way myself.
