Author Topic: Input Problems With MAME  (Read 1015 times)
matt.e
  • Last login:September 02, 2004, 02:45:56 pm
« on: November 16, 2003, 05:14:31 pm »
I'm having some input problems when using MAME with my x-joy converter (x-box>PC converter)
the controls take varying ammounts of time to respond. The d-pad takes the longest whereas the A,B/X,Y are a bit quiker. the d-pad can take 6-7+ seconds to respond (if you push left then release it there will be no movement at any time whereas if you push and hold it then release it when there is movement you will stop when you release it.
THIS IS A MAME SPACFIC PROBLEM. the control works fine with other emu's and in the test program.
i have deleted ALL mame roms/exe's, everything and even reverted to an older version.
other pads work fine, connections are good and hardware seems to be OK.
If anyone can help OR has had similar problems they wouls be great,
matt.e
note: i turned on error log and this is a few lines of the tens of thousends i got. dunno what any of it means as far as my problems go.
PC = cb7c : Unknown bank selected (ff)
EEPROM read 0033 from address 33
EEPROM read 0034 from address 34
EEPROM read 0035 from address 35
EEPROM write 0056 to address 56
EEPROM lock
EEPROM unlock
EEPROM write 0057 to address 57
EEPROM lock
Why don't they just leave me alone!
matt.e
Re:Input Problems With MAME
« Reply #1 on: November 16, 2003, 05:40:02 pm »
Hi,
I have science solved (some) of this problem by disableing the RDSC timing system. But now the timing is way out.
This has not solved all of the problems with the input but it has screwed the timing of cause.
the error log not reads,
cpu #0 (PC=00000009): unmapped memory byte write to 00005071 = 00
cpu #0 (PC=00000009): unmapped memory byte write to 00005072 = 00
cpu #0 (PC=00000009): unmapped memory byte write to 00005073 = 00
cpu #0 (PC=00000009): unmapped memory byte write to 00005074 = 00
cpu #0 (PC=00000009): unmapped memory byte write to 00005075 = 00
etc.
more help (with the problem not my spelling) would be great,
matt.e
