Author Topic: 2 quick questions about NovaGems  (Read 1381 times)
Muniosi
  • Last login:October 31, 2013, 09:32:20 pm
« on: August 16, 2013, 01:28:30 pm »
1) Anyone know what size holes to use on the round NovaGem buttons? I ask because I'm considering replacing the buttons in my current control panel.
2) How does one power the buttons? On the site it said to connect it to a 5v power source, but do the buttons have a connector on them already, or will I have to do some soldering?
Thanks in advance.
  • Last login:Today at 02:42:24 pm
Re: 2 quick questions about NovaGems
« Reply #1 on: August 16, 2013, 01:59:04 pm »
Welcome aboard, Muniosi.
The Novagems use a standard 1-1/8" mounting hole AFAIK.
There are two things that make the round Novagems different from other LED buttons:
1. 'Pre-Attached 24" wires with resistor termination.' The wires are visible on the left side of the blue button in this MPG.
2. 'Power Requirements: 100ma @ 5v DC Per button.' 18 buttons (12 player buttons, P1/P2 Start, P1/P2 Coin, Pause, and Exit) = 1.8 Amps.   :o
Plan your power source accordingly -- 5v from the red/black wires on a computer power supply molex connector should work fine.
Do you plan on having them always on, or will you use a controller to switch them on/off?
Muniosi
« Reply #2 on: August 16, 2013, 03:31:01 pm »
Thanks for answering.
What is on the end of these wires? Is there a connector or just bare wire?
I figured I'd have them always on, so I wouldn't have to buy a control board.
« Reply #3 on: August 16, 2013, 05:02:42 pm »
Not sure, but since Randy's LED controllers (LED-Wiz+GP and LED-Wiz) have screw terminals, I'm guessing no connector.   :dunno
When you place your order, consider including some euro-style terminal blocks to hook all the wires up neatly.
Daisy chain along one side (shown) including either the red (+) or black (-) wire from the molex.
Connect all the LED wires of the same polarity (+ or -) along the other side.
Don't forget to verify that your daisy chain wire is capable of handling the amount of current your buttons will draw.
« Last Edit: August 16, 2013, 05:05:12 pm by PL1 »
Muniosi
« Reply #4 on: August 16, 2013, 06:08:53 pm »
Cool, thanks! That seems fairly simple. Now to wait until they come back in stock... :p
« Last Edit: August 16, 2013, 07:11:12 pm by Muniosi »
« Reply #5 on: August 16, 2013, 08:04:09 pm »
Drop RandyT an e-mail and let him know what all you're looking for, he may still have some even though they don't show up on the webpage.   :cheers:
All colors NovaGem2's are in stock...  email me if you need some.  I had hoped to get these on the store by now, but I can't seem to catch a break with the recent order volume and all of the projects I have been working on.
