Author Topic: Help with Eightball Pin  (Read 2674 times)
spag256
  • Last login:January 13, 2017, 07:12:17 pm
« on: August 01, 2013, 05:33:00 pm »
When I perform a solenoid test on my eightball pin the Outhole kicker,Side return kicker,Left,Right and bottom thumper bumpers,left and right slingshot and the coin lockout door solenoids don't respond. Only the Knocker,Chimes and flippers respond. I purchased a new solenoid driver module and the same solenoids don't respond. What can I do?
smartbomb2084
  • Last login:January 13, 2021, 03:14:53 pm
  • Having a SMART phone will make you DUMB.
Re: Help with Eightball Pin
« Reply #1 on: August 01, 2013, 10:43:07 pm »
Check the under-playfield mounted fuse located to the right of the right flipper assembly...
If it is good... Check for +43VDC at all of the playfield coils....
« Last Edit: August 01, 2013, 10:57:03 pm by smartbomb2084 »
« Reply #2 on: August 02, 2013, 09:11:50 am »
Might want to look at the wiring diagram, too.  If those are all after a certain point in the wiring then you have a break in the circuit on the ground line.  If this is the case look at the ground line between the last working coil and the first dead one.
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #3 on: August 02, 2013, 09:32:12 am »
Just in case you don't have the schematics:
http://www.ipdb.org/search.pl
