Author Topic: Any mini cocktail designs out there?  (Read 6728 times)
404
« on: August 01, 2013, 11:46:50 am »
Time for my annual derp-cade that i will likely screw up, never finish and/or throw away.  ;D
So i have a few laptops here and was thinking about making a mini cocktail cabinet similar to the one below. I've searched around but unfortunately couldn't find any plans like these. Does anyone know if there are any freely available ones online?
http://www.homeleisuredirect.com/Assets/HLD/User/8572-36337_10151279602598980_65656254_n.jpg
jdbailey1206
Re: Any mini cocktail designs out there?
« Reply #1 on: August 01, 2013, 12:01:38 pm »
Here is what I could find.  Nothing solid yet.  But you could almost use these as a template and size them to your laptop screen...
404
« Reply #2 on: August 01, 2013, 12:24:43 pm »
^^ I knew i had seen those plans before somewhere.  Thanks! :)
  • Last login:Today at 03:54:39 am
« Reply #3 on: August 01, 2013, 12:26:52 pm »
How about Joel's Little Ms. Pac-Man?
« Reply #4 on: August 01, 2013, 02:17:55 pm »
thought of it but i was looking for something a bit more classical looking. It is a great project though :)
BleedinFingers
  • Last login:April 03, 2014, 05:23:47 pm
« Reply #5 on: August 10, 2013, 04:53:15 pm »
Heres the one I designed, It's pretty compact for a cocktail cabinet as it is used as my coffee table but has replacable legs to change the height if needed.
Can let you have sketchup plans If you like
paigeoliver
  • Awesome face!
« Reply #6 on: August 10, 2013, 07:32:11 pm »
I have seen what you are talking about in person and, well, you really don't want that.
404
« Reply #7 on: August 10, 2013, 07:50:56 pm »
I actually made two side panels for a mini centri track and field cocktail. Unfortunately i only have a jiggsaw here and it came out quite crooked. I'm in way over my head again so i won't be working on it any more.
mann0mann
  • Last login:June 25, 2016, 12:31:54 pm
  • Still looking for the right project...
    • My Hobby Store
« Reply #8 on: August 12, 2013, 02:19:42 am »
BleedingFingers - do you think I could get a copy of those?  I like your design...it might get me past the wife obstacle... :-)
Vebbo
    • Overaged Lucky Drivers
« Reply #9 on: August 12, 2013, 08:16:51 am »
+1 on those sketchup files  :applaud:
Vebbo
jdbailey1206
« Reply #10 on: August 12, 2013, 09:28:36 am »
Bummer.  I was looking forward to seeing this little guy completed.  Just wondering if you have anyone you could borrow tools from?
CoryBee
  • Bopity Boopy
« Reply #11 on: August 12, 2013, 09:34:25 am »
You could make a guide for the jigsaw to do straight cuts. It is what I did on my first bartops.
404
« Reply #12 on: August 12, 2013, 10:01:47 am »
Nobody that i know of unfortunately. Used to have a bunch of carpenter and welder friends when i was younger.
I thought of using a guide this time around but the last time i tried that, the saw started veering to one side and ruined a piece of wood i had.
Probably should have cut the wood before gutting the laptop.  ;D
bluemini17
  • Last login:June 06, 2014, 10:26:11 am
    • My Youtube Channel
« Reply #13 on: August 12, 2013, 10:12:54 am »
i made one a few years ago. i got the jakobud plans and scaled them down to fit a 15inch screen. here is the youtube vid i made for it a few years ago.
404
« Reply #14 on: August 12, 2013, 02:01:40 pm »
Looks awesome bluemini!
BleedinFingers
« Reply #15 on: September 23, 2013, 06:23:57 am »
Here you go guys, unfortunately I'm a bit better at building than making the plans but they should give you a pretty good idea how it went together.
All done with basic tools, jigsaw, router, sander etc.  I did use a table router to make the legs but only really because I wanted them to be able to slide on and off to change the height.  The control panels were a bit tricky as I wanted them as thin as possible to give plenty of hand clearance below the glass and it was real tight fitting the buttons in.  All bottom panels including the CPs are hinged to allow access
« Last Edit: September 23, 2013, 06:50:01 am by BleedinFingers »
eds1275
  • Last login:November 05, 2025, 09:52:44 am
  • Rock and Roll!
« Reply #16 on: September 23, 2013, 02:10:22 pm »
I came across some tempered glass from a broken nintendo cab and was all like "what could I do with this?" so I am 99% completed the woodworking on this:
macattack
  • Last login:August 03, 2018, 05:35:16 pm
  • Cabinet builder to the stars!
« Reply #17 on: September 23, 2013, 02:27:54 pm »
Liking this, may have to give one a go.
WWW.Xtremepinball.com
Pm me for custom cnc needs...
404
« Reply #18 on: September 23, 2013, 02:40:44 pm »
really liking that design but considering it came from a nintendo cab, why not make it look a little more traditional and convert it into a playchoice themed cocktail design?
eds1275
  • Rock and Roll!
« Reply #19 on: September 23, 2013, 02:51:33 pm »
I only got the glass from a nintendo cab. It was an upright, but the glass was a good size to make this cocktail for the back of my office. I'm not going to pay homage to a rotten old nintendo cab that ended up in the landfill.
BleedinFingers
« Reply #20 on: October 05, 2013, 12:18:37 pm »
I'm thinking of adding some side by side CPs to my table, what do you think? Either that or have a couple of normal usb arcade sticks.  Current thinking is go for the usb sticks as will be more comfortable on the sofa and give a bit more elbow room
