Author Topic: Problems Exiting back to MA  (Read 3243 times)
mastermark
  • Last login:August 10, 2013, 04:21:35 pm
« on: July 29, 2013, 11:21:03 am »
Im using esc to exit the emulators back to MA but it dont seem to work
Where are the settings to change the exit button or is there ???
Re: Problems Exiting back to MA
« Reply #1 on: July 29, 2013, 11:30:34 am »
Are you double pressing or holding it for longer periods?  I'm a MA n00b but IIRC MA uses a monitoring script to kill the target process and return the FE.  The MA page mentions that you might need to hold it longer or press ESC a few times to get the script to execute correctly.  I've noticed this on a few different EMUs and even some MAME roms over this last weekend.  Give it a shot and see if that works for you better.
mastermark
« Reply #2 on: July 29, 2013, 11:39:38 am »
Thanks mate I've found out if i change the " Quit Executable " to TAB works Fine  :applaud:
