Author Topic: Which paper to print on? HELP!  (Read 2080 times)
MartinJames
  • Last login:March 28, 2021, 10:10:33 am
« on: July 20, 2013, 07:17:11 am »
I have just purchased an Epson 7800 PRO A1 Printer. Which Paper Roll should I buy to enable me to print control panels? Should I then laminate it? If so which laminator should I buy?
Martin
Felsir
  • Last login:July 09, 2025, 03:34:33 am
  • Creating cab artwork
    • Felsir's World
Re: Which paper to print on? HELP!
« Reply #1 on: August 06, 2013, 07:42:24 am »
For control panels, you will probably want to protect the art by a sheet of plexiglass or lexan. In that case any paper will do that suits your level of desired print quality. I recommend a glossy type of paper for a nice effect.
If you don't want to have a sheet of plexi, you will have to print on different material such as vinyl. For example this: http://www.photopaperdirect.com/categories/Creative-Media/Creative-Stickers/. I'm not sure if you also need special inks or the compatibility with your printer. Since you're printing, I'd still recommend going for plexiglass to protect your artwork. For the sideart- this might suit your needs.
