Author Topic: Trackball/Windows axis problem  (Read 1022 times)
surface tension
  • Last login:July 01, 2018, 08:45:48 am
  • feel the tension...
    • surface tension tables
« on: June 27, 2013, 08:26:59 am »
I've got a strange issue going on with a trackball and thought I'd throw it out here. I've installed loads of these and never seen this issue before, so I'm stumped.
I have a Happ trackball, connected to a Minipac which has stopped working on the y-axis. Initially I thought it was the encoder board. So I swapped this out and nothing changed. I tried another Minipac with the same result. I connected a mouse and this works fine.
So I then started to look at deleting the driver and letting it find it again, so switched to the Admin account so I wasn't constantly putting in the password. Well, the trackball works in this account. So I switched back and confirmed, it works in one Windows user account and not the other.
So, to get it working again (I assume), I can create another user account and configure, but I don't like not knowing what's happened! Plus, it could happen again. I have no idea how it happened, but it was some time during the Revival show last month whilst out in the wild.
Any help is appreciated, thanks.
Hoopz
  • Last login:December 02, 2025, 03:05:33 pm
  • Intellivision Rocks!
Re: Trackball/Windows axis problem
« Reply #1 on: June 27, 2013, 08:36:02 am »
Wow, that's odd.  What version of Windows?  I wonder if it has something to do with the UAC (or whatever it's called now)?
Dawgz Rule
  • Last login:August 22, 2024, 07:18:55 pm
  • The more people I meet, the more I like my dogs
« Reply #2 on: June 27, 2013, 09:25:32 am »
Off the top of my head it could be a profile issue or it could be some sort of permissions issue although both seem somewhat strange.  I would make the user that it doesn't work an administrator on the computer and see if that fixes it.
« Last Edit: June 27, 2013, 11:12:12 am by Dawgz Rule »
surface tension
« Reply #3 on: June 27, 2013, 11:09:45 am »
Thanks for the replies.
It's Windows 7 Home Premium.
That seems like a good step to try Dawgz. I'll have a go later.
surface tension
« Reply #4 on: July 01, 2013, 08:25:20 am »
I tried changing the user account to admin, but no joy. Thanks for the suggestion.
Unless anyone else has any ideas, it looks like I'll need to create a new user account.
