Author Topic: Looking for specific LCD bracket which...  (Read 1311 times)
Dariusz
  • Last login:November 23, 2018, 02:41:36 pm
« on: June 16, 2013, 07:16:01 am »
Hi
I need help in locating (ideally in Australia) a specific LCD bracket which can be used on a 42" LCD screen, but has the primary function of:
* Being able to rotate the LCD screen 90 degrees from a horizontal position to a vertical position and back whenever required by just turning the screen by hand (or motorised).
I look forward to your replies.
D
Drnick
  • Plodding Through Life
Re: Looking for specific LCD bracket which...
« Reply #1 on: June 16, 2013, 01:44:22 pm »
http://www.pinnaclemicro.com/computer/dsku.php?g=TH-3050-RW-TAA&m=Atdec
Might be worth seeing if you can find a datasheet, but it looks like it should do the job. They have a little video on the Site below that shows it doing what you want.
Here is an Aussie supplier.
http://www.atdec.com.au/content_common/pr-telehook-wall-range_30-50-wall-rotating.seo
