Author Topic: U-HID G: Opinions?  (Read 2437 times)
GeoMan
  • Last login:August 04, 2025, 01:36:26 pm
U-HID G: Opinions?
« on: June 08, 2013, 04:17:06 am »
How good is the U-HID G for pinball nudge functions? Is it responsive? Reliable? Any alternatives?
Using the 3 axes for nudge operations, it leaves 5 connections for 2 left, 2 right flippers and a plunger button, which is enough for pinball control. Does it support the "shift" function as the original U-HID does?
I plan to use it to built a Pinball controller...
  • Last login:Today at 04:23:36 am
Re: U-HID G: Opinions?
« Reply #1 on: June 08, 2013, 09:54:03 am »
See the link in my sig for my pin controller and U-HID-G settings.
It works ok for a digital nudge, but I never revisited to see if it can do analog nudging.
For analog nudging, Noah over on VPForums.org just recently released VirtuaPin™ Digital Plunger Kit.
It's his answer to the older Nanotech Mot-Ion kit that has some calibration, stability and heat-sensitivity issues.
Early reviews on the VirtuaPin Plunger Kit appear to be promising, but the sample size is still too small to be sure -- keep an eye on Noah's announcement thread to see how things shake out.
EDIT: Forgot to mention, but if you want to avoid messing with accelerometers, KADE has a Pinball map that works great.
« Last Edit: June 08, 2013, 11:18:44 am by PL1 »
