Author Topic: Bent dynamo control panel  (Read 3720 times)
iscariot
  • Last login:April 02, 2025, 12:44:33 am
« on: June 03, 2013, 04:58:36 pm »
I've got a bent Dynamo sheet metal control panel.  Any suggestions to make it workable?  I got a suggestion to use another metal piece over top of it, or a piece of wood.  That the best method?  The bend is slight, more of a dent.  Would just bondo'ing the thing be the best option?
Monkeyvoodoo
  • Last login:November 16, 2024, 01:36:41 am
  • I swear I can stop at one. Or two.
    • threefoldhorse Custom
« Reply #1 on: June 03, 2013, 05:37:11 pm »
All depends on how bad it is. You can use bondo (that is its main purpose) If its a shallow dent. If its relatively deep you could pop it out like they would on a car.
Hard to give accurate advice without a pic 😄
Sent from where ever I happen to be.
Re: Bent dynamo control panel
« Reply #2 on: June 05, 2013, 11:16:52 am »
mgb
  • North East, US
« Reply #3 on: June 05, 2013, 11:57:56 am »
Definitely a pic would help.
Does the dent fall in an area where something is to be mounted? Cause if its bad and you just bondo the top, it will look good up top but whatever gets mounted there, like say a joystick may not be straight.
You could basically get it straight with a ball peen hammer and a good solid metal surface and then bondo to make it all nicey nice.
iscariot
« Reply #4 on: June 06, 2013, 04:15:22 pm »
Looks a lot like Malenko's but with some dents...looks like someone took a bat to it a few times.
Monkeyvoodoo
« Reply #5 on: June 06, 2013, 06:33:43 pm »
plexi on top
 went from this:
to this:
http://forum.arcadecontrols.com/index.php/topic,120488.msg1278327.html
That's a lot of holes. I guess the lighter the CP the faster the game runs, 😉
