Author Topic: Gun2Naomi : Homemade Sega Naomi (JVS and PC) gun  (Read 16709 times)
aganyte
  • Last login:March 08, 2024, 03:55:09 am
« on: May 08, 2013, 02:43:12 am »
Hi all,
After the L2HAPP (logitech wheel to Happ wheel power board)
http://www.gamoover.net/tuto/happ-controls-interfacer-un-retour-de-force-happ-sur-un-pc-ps-2-et-ps3
After the L2M2 (logitech to Sega model 2 wheel power board)
http://www.gamoover.net/tuto/l2m2-interfacer-un-ffb-et-volant-sega-model-12-avec-un-pc-ou-une-playstation-23
My new project (i'm allready search name  ;D)
Homemade Sega Naomi gun
Coming soon on Gamoover.net  ;)
Edit : Also works on, Chihiro, Triforce and Lindbergh.
« Last Edit: November 03, 2013, 04:07:07 am by aganyte »
Paladin
  • Mmmm llamaburgers!
Re: Homemade Sega Naomi gun
« Reply #1 on: May 08, 2013, 08:38:36 am »
Are you running the Naomi on an emulator, or the real hardware?  You've got so much stuffed into your cab that I can't tell!  I watched the whole video, but unfortunately I'm not bilingual!
aganyte
« Reply #2 on: May 08, 2013, 11:20:49 am »
It's an original Naomi 2 with CF reader. I've also a Neo geo MV1FZ with 120 in 1 cartridge in the cab (i select the system with one sanwa button at the rear of the cab)
You can see all my youtube video for more details on this New astro.
aganyte
« Reply #3 on: May 11, 2013, 01:53:08 pm »
New update  ;D
Passage de la précision du gun à 256 points x 256 points (identique à l'original)
Temps de calcul des coordonnées de 2.5/100eme de secondes (contre 1/10eme de secondes pour la première vidéo)
Gestion du Reload (il suffit de viser en dehors de l'écran)
Rajout d'un menu de vérification des sources parasites infra-rouge.
Possibilité de mettre la barre émettrice dessus ou dessous l'écran et plus ou moins éloignée du bord de ce dernier.
Position du curseur conservé en cas de perte momentané du signal.
  • Last login:Yesterday at 12:04:48 pm
« Reply #4 on: May 11, 2013, 03:00:35 pm »
I wish I had 10% of your talent when it comes to interfacing things.   :notworthy:
aganyte
« Reply #5 on: May 17, 2013, 04:17:22 pm »
CoryBee
  • Bopity Boopy
« Reply #6 on: May 17, 2013, 05:29:40 pm »
One of three situations where having a frenchie for a girlfriend comes in handy. She walked in and said, "do i hear french?" and translated.
On that note GREAT JOB.
Sur ce, c'est vraiment du bon boulot!
« Reply #7 on: May 17, 2013, 09:32:13 pm »
Does it not have the white flash if not using an original gun board?
That would be a nice benefit.
Paladin
« Reply #8 on: May 17, 2013, 09:55:04 pm »
Stock Naomi gun games use a 10 LED sensor ring, 5 above and 5 below the monitor.  The LEDs track the gun, so no flash. Unfortunately the system is expensive and has some reliability issues. This is why a 'simple' cheaper solution would rock.
I'm about to drill 10 holes in an otherwise beautiful monitor surround to get my gun cab running.  This solution would allow the use of an easily removable sensor bar with much less cosmetic damage, not to mention the price of a Naomi LED sensor setup is about $100 with about the same for the gun board and each gun!
aganyte
« Reply #9 on: May 18, 2013, 02:19:28 am »
thanks for interest  ;D
Now, the project has a name => G2N : Gun2Naomi
The link for the "how to" in french (he's not finish)
http://www.gamoover.net/Forums/index.php?topic=27895.0
I think the price for one complete gun is about 100$ (150$ for two complete gun)
You must have for one gun
-Standard sega IOBoard
-one wireless Wii sensorbar
-one old nintendo wiimote (original not a copy)
-one G2N (Gun2Naomi) Mainboard
-one G2N pistol board
aganyte
« Reply #10 on: May 18, 2013, 06:58:40 am »
New video
aganyte
« Reply #11 on: May 21, 2013, 10:29:51 am »
New video with "just for fun" wii bar installation
aganyte
« Reply #12 on: June 02, 2013, 03:51:28 am »
New "How to" topic update (pictures, pcb, movies)
aganyte
« Reply #13 on: June 05, 2013, 01:01:26 pm »
House of the dead 2 (Original Naomi hardware)
« Last Edit: June 09, 2013, 08:19:03 am by aganyte »
aganyte
« Reply #14 on: June 08, 2013, 08:09:08 am »
First Mame test
aganyte
« Reply #15 on: June 09, 2013, 07:48:50 am »
House of the dead (Nebula M2)
« Last Edit: June 09, 2013, 08:18:15 am by aganyte »
aganyte
« Reply #16 on: June 09, 2013, 08:17:40 am »
House of the dead 3 PC
aganyte
« Reply #17 on: June 12, 2013, 04:10:33 am »
Gun2Naomi setup by Iro (Gamoover forum)
Main Board
Pistol Board (in Guncon 45)
aganyte
Re: Homemade Sega Naomi (and PC) gun
« Reply #18 on: June 15, 2013, 09:43:11 am »
The lost world (Supermodel) on 47" inch lcd Tv
Superfrog
    • My YouTube Channel
« Reply #19 on: June 15, 2013, 11:04:43 am »
Good to see some gun project.
Loved the guns on my Dreamcast back then.
So maybe for some other project in the near future  >:D
Keep a eye on it  :cheers:
aganyte
« Reply #20 on: November 03, 2013, 04:06:21 am »
Hi all,
Some news on this project.
The final tutorial is here
http://www.gamoover.net/tuto/gun2naomi
and the lindbergh test is here
http://www.gamoover.net/Forums/index.php?topic=27895.672
Paladin
Re: Gun2Naomi : Homemade Sega Naomi (JVS and PC) gun
« Reply #21 on: November 03, 2013, 08:31:34 am »
That's some incredible work!
