Author Topic: R-91 amp  (Read 1659 times)
mountaindew
  • Last login:March 13, 2015, 03:29:13 pm
R-91 amp
« on: May 02, 2013, 05:31:30 pm »
Will a 250 watt rowe amp work in a R-91 that had a 130 watt amp
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: R-91 amp
« Reply #1 on: May 03, 2013, 10:17:12 am »
Yes you can fit a 250 watt amplifier, however I would suggest that you put the phono speakers on a lower tapping on the output package, down to E4 or E3 on both channels and for the full output use extension speakers.
Regards
Alan
Alan Hood
ami-man
UK
mountaindew
Re: R-91 amp
« Reply #2 on: May 03, 2013, 11:34:41 am »
Thank you.Can you tell me if the plugs will be the same.The amp is out of a R-90.Also,if the transistors in the amp are bad will this make the volume not work and have distortion in the sound of the speakers
jdemarti
  • Last login:May 31, 2022, 10:57:25 am
Re: R-91 amp
« Reply #3 on: May 03, 2013, 05:16:48 pm »
Yes, it should be interchangeable.
As for the static.  Are you getting static out of both channels or just one? Also, check the fuses on the driver board. If they are blown, then is it most likely the transistors.
mountaindew
Re: R-91 amp
« Reply #4 on: May 03, 2013, 05:28:28 pm »
Static is more out of one then the other.The fuses are all good
« Last Edit: May 03, 2013, 07:28:31 pm by mountaindew »
jdemarti
Re: R-91 amp
« Reply #5 on: May 03, 2013, 08:57:28 pm »
It sounds like a transistor is failing (not completely shorted yes).  I would try a new set of 2n6284 and 2n6287 transistors.  My advice would be to stay away from E-bay; you run the risk of counterfeits.  Buy them from reputable places such as Mouser or Future Electronics.
Good luck
mountaindew
Re: R-91 amp
« Reply #6 on: May 04, 2013, 02:18:51 pm »
Thank you very much
mountaindew
Re: R-91 amp
« Reply #7 on: May 09, 2013, 06:30:18 pm »
I replaced all 4 transistors and now it sounds 100% better but it is still about half way with volume.I can not change the volume higher or lower.If I turn the volume knob it gets just a little louder but not much. What would be the next step to try
« Last Edit: May 13, 2013, 08:18:39 pm by mountaindew »
