March 21, 2026, 01:16:57 am
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon Arcade Stuff
through our link. Thank you!
Main
Audio/Jukebox/MP3 Forum
R-91 amp
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: R-91 amp (Read 2001 times)
mountaindew
Trade Count:
0
Full Member
Offline
Last login:March 13, 2015, 03:29:13 pm
R-91 amp
on:
May 02, 2013, 05:31:30 pm »
Will a 250 watt rowe amp work in a R-91 that had a 130 watt amp
Logged
ami-man
Trade Count:
0
Full Member
Offline
Last login:July 19, 2020, 01:22:45 pm
Re: R-91 amp
Reply #1 on:
May 03, 2013, 10:17:12 am »
Yes you can fit a 250 watt amplifier, however I would suggest that you put the phono speakers on a lower tapping on the output package, down to E4 or E3 on both channels and for the full output use extension speakers.
Regards
Alan
Alan Hood
ami-man
UK
Logged
mountaindew
Trade Count:
0
Full Member
Offline
Re: R-91 amp
Reply #2 on:
May 03, 2013, 11:34:41 am »
Thank you.Can you tell me if the plugs will be the same.The amp is out of a R-90.Also,if the transistors in the amp are bad will this make the volume not work and have distortion in the sound of the speakers
Logged
jdemarti
Trade Count:
0
Full Member
Offline
Last login:May 31, 2022, 10:57:25 am
Re: R-91 amp
Reply #3 on:
May 03, 2013, 05:16:48 pm »
Yes, it should be interchangeable.
As for the static. Are you getting static out of both channels or just one? Also, check the fuses on the driver board. If they are blown, then is it most likely the transistors.
Logged
mountaindew
Trade Count:
0
Full Member
Offline
Re: R-91 amp
Reply #4 on:
May 03, 2013, 05:28:28 pm »
Static is more out of one then the other.The fuses are all good
Last Edit: May 03, 2013, 07:28:31 pm by mountaindew
Logged
jdemarti
Trade Count:
0
Full Member
Offline
Re: R-91 amp
Reply #5 on:
May 03, 2013, 08:57:28 pm »
It sounds like a transistor is failing (not completely shorted yes). I would try a new set of 2n6284 and 2n6287 transistors. My advice would be to stay away from E-bay; you run the risk of counterfeits. Buy them from reputable places such as Mouser or Future Electronics.
Good luck
Logged
mountaindew
Trade Count:
0
Full Member
Offline
Re: R-91 amp
Reply #6 on:
May 04, 2013, 02:18:51 pm »
Thank you very much
Logged
mountaindew
Trade Count:
0
Full Member
Offline
Re: R-91 amp
Reply #7 on:
May 09, 2013, 06:30:18 pm »
I replaced all 4 transistors and now it sounds 100% better but it is still about half way with volume.I can not change the volume higher or lower.If I turn the volume knob it gets just a little louder but not much. What would be the next step to try
Last Edit: May 13, 2013, 08:18:39 pm by mountaindew
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
R-91 amp
