Author Topic: Contact cement toxic?  (Read 8091 times)
fablog
  • Last login:July 07, 2025, 10:10:01 pm
« on: April 08, 2013, 07:07:04 pm »
Hi Guys,
I may need to laminate my cab inside my home depending of the weather this days. I would like to know if contact cement is too much toxic for that?
Thank you
silar
  • Last login:May 06, 2013, 10:13:19 pm
  • Nerd with a project! WOOT!
Re: Contact cement toxic?
« Reply #1 on: April 08, 2013, 07:13:12 pm »
You'll definitely want to make sure you have a lot of ventilation.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #2 on: April 08, 2013, 07:14:50 pm »
Um, doesn't every kid know that something industrially-based, while it might smell maigh-ty goood....god I miss regular gasoline.....is carcinogenic?
-Banned-
BobA
  • What Me Worry?
« Reply #3 on: April 08, 2013, 10:27:02 pm »
Not toxic if it used properly.  Lots and lots of fresh air when going from glue to semi tacky and and give it another day to finish off gassing.   After that it is what laminate is always applied with and is under millions of countertops and is perfectly safe unless you want to eat it or some other strange method of contact.
CpCaveman
  • Last login:January 06, 2018, 11:43:05 am
  • Contains 0% horsemeat , may contain BULL though :)
« Reply #4 on: April 08, 2013, 10:46:11 pm »
Call me old fashioned but ever since the great shampoo drinking disaster of the early 70`s (when i was born so it answers a lot :) ) the manufacturer should actually state that on the tin  :dunno I`d rather rely on that information than what someone says in a forum when the word toxic is in question  :dizzy: mmmmm shampoooo......
Hit something hard enough it should work, if it dont the result can always be called art :)
  • Last login:Today at 06:31:54 pm
« Reply #5 on: April 08, 2013, 10:53:23 pm »
The four magic letters are "MSDS".
Go to the manufacturer's website and they should have a link to the Material Safety Data Sheet (MSDS) which will tell you what you need to know about potential dangers working with the material and any Personal Protective Equipment (PPE) that you should use.
michelevit
  • Last login:December 25, 2024, 06:57:41 pm
« Reply #6 on: April 09, 2013, 10:12:47 am »
I've used contact cement and find that its odor, like its bonding strength is super strong. I recommend applying it outside or in a open garage.
TLDR: Its stinky- your wife will hate you if you apply it indoors.
fablog
« Reply #7 on: April 09, 2013, 05:19:12 pm »
Thank you guys for these informations! outdoor it will be! -5 celsius the day I take the day off  :angry:
eds1275
  • Last login:Today at 11:32:44 am
  • Rock and Roll!
« Reply #8 on: April 10, 2013, 12:15:33 pm »
I used the water based contact cement inside with no problams. Just an open window and closed doors, and I did it in a room I had no hurry to be in. http://lepageproducts.com/ProductDetail.aspx?pid=89
gamepimp
  • Last login:April 06, 2025, 08:48:37 pm
« Reply #9 on: April 10, 2013, 07:55:54 pm »
I think the water based stuff is the way to go. The petroleum based stuff should prob not be used inside. It will a) make u high as a kite, b) stink up ur house, and c) could combust if ur near any kind of open flame (furnace, water heater, fireplace, etc). I'm going to try the water based cement on my next build to avoid all those hassles of the other stuff.
lilshawn
  • Last login:August 19, 2025, 11:56:37 pm
« Reply #10 on: April 11, 2013, 02:44:30 pm »
you better not be gettin' high off of them fumes, i'll have to charge ya.
