Author Topic: Question about Player 1 Start plus Player 2 start to exit Mala  (Read 2543 times)
colonelsnow
  • Last login:July 13, 2022, 07:56:26 am
I thought that Mala came with the default exit of Player 1 + Player 2 , however that is not working for me. I am using a jpac. Do I need to be using something like autohotkey for this button combination to work or is their another way?
dgame
  • I am no Jedi
Re: Question about Player 1 Start plus Player 2 start to exit Mala
« Reply #1 on: March 14, 2013, 10:00:17 am »
If I recall correctly Player 1 + Player 2 on the  Jpac sends the  "Esc" (Escape) key. So set the Escape key to exit in Mala and it should work.
colonelsnow
« Reply #2 on: March 14, 2013, 12:24:06 pm »
Do you know if this is true even if the Jpac is connected only through the jamma connector rather than being wired through he individual input terminals on the Jpac?
dgame
  • I am no Jedi
« Reply #3 on: March 14, 2013, 12:38:43 pm »
The keys should behave the same.
To test for the escape key open Notepad and drop down the File menu.
Pressing Escape will close the menu.
