October 12, 2025, 11:20:54 am
Good to hear! I used 5V LED bulbs with a PACLED64 for my reject buttons in the Two-Headed Beast. Check out posts 175 and 181 on page 5 of my build thread in my signature.
That's because an IPAC can't power LEDs. You need either: A) An LED controller such as a PACLED64 or LEDWiz in combination with software such as LEDBlinky to control your LEDs however you want; or B) Wire your LEDs to the appropriate voltage on your power supply to have them always on when the machine is on.
Verify your wiring is correct: http://ultimarc.com/pacled64.htmlAnd the PACLED64 needs to be connected to your power supply in addition to a USB port. Make sure you've got it connected to the appropriate voltage on your power supply (red wire if using 5V LEDs, yellow wire if using 12V LEDs).
Take the bulbs out, turn them 180 degrees, and reinstall.
That's not an LED bulb, that's an incandescent bulb. LED controllers can't light incandescent bulbs.
Also, Paradise Arcade Shop.
Yeah.
