Author Topic: Coin Slot to work with Ipac2?  (Read 6847 times)
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« on: March 10, 2013, 07:00:40 pm »
I found the switch on my coin slot in my Dig Dug Cabinet which "should" trigger the coin insert for my front end.  I use WinPac to configure the IPAC2 and I can see the switches seem to communicate with the IPAC and no errors on the card.  If I put the wire to the always closed switch(I did this for a test) and see it does light up inside of WinPAC.  I attach to the other prong like the button switches but I honestly have no idea where the ground goes and I think that is where the issues lies.  Someone hand wrote a "G" on the frame right below the switch I am using but it does not have the extra prong I see with the micro switches I use for the buttons.  Not sure if anyone has any info or if you need to see a pic.
Thanks,
Rich
« Last Edit: March 12, 2013, 08:20:57 am by rtkiii »
rtkiii
Re: Coin Slot to work with Ipac2?
« Reply #1 on: March 12, 2013, 07:10:58 am »
Here Are the pictures.
1st Pic is full shot of two slot coin
2nd Pic side view of where I have my cable running to the IPAC2
3rd Pic is a 3/4 shot a little closer in showing the "G" I mentioned above.
« Reply #2 on: March 12, 2013, 09:04:40 am »
You have your wires hooked up to electromagnets, not the coin switches which are blue and on the bottom of your assemblies... Wire those switches up just like your buttons, COM to IPAC ground, and NO to your desired IPAC input.
rtkiii
« Reply #3 on: March 12, 2013, 12:17:07 pm »
LOL - I saw the copper coil or something near these and wondered what the heck these things were.  LOL  The is a little switch just below the prongs I am using which made me think this had to be it.  I thought the blue ones were for a counter.  :)  Thanks I will give it a whirl tonight.
rtkiii
« Reply #4 on: March 12, 2013, 04:00:52 pm »
SIDE NOTE:  I have a LEDPAC64...can I run the lights from the LEDs in the coin slot to that the same way I will do my single color LEDs?  I have not received my cabling yet but I am just curious
thanks,
Rich
rtkiii
« Reply #5 on: March 13, 2013, 07:27:24 am »
I had to remove some solder from the switches but once I did that they work with the IPAC....thanks for the help, Nephasth!
« Reply #6 on: March 13, 2013, 09:43:52 am »
Good to hear! I used 5V LED bulbs with a PACLED64 for my reject buttons in the Two-Headed Beast. Check out posts 175 and 181 on page 5 of my build thread in my signature.
« Last Edit: March 13, 2013, 09:46:23 am by Nephasth »
rtkiii
« Reply #7 on: March 22, 2013, 07:42:51 am »
I connected my LEDs up like the normal buttons to the IPAC but they are not powering on...good chance the bulb is burnt out I guess.  Need to order some.  Referring to your post you mentioned.  thanks!
« Reply #8 on: March 22, 2013, 08:35:10 am »
That's because an IPAC can't power LEDs. You need either: A) An LED controller such as a PACLED64 or LEDWiz in combination with software such as LEDBlinky to control your LEDs however you want; or B) Wire your LEDs to the appropriate voltage on your power supply to have them always on when the machine is on.
rtkiii
« Reply #9 on: March 22, 2013, 08:50:39 am »
Sorry I miss typed.  I have a PACLED64.
« Reply #10 on: March 22, 2013, 09:03:04 am »
Verify your wiring is correct: http://ultimarc.com/pacled64.html
And the PACLED64 needs to be connected to your power supply in addition to a USB port. Make sure you've got it connected to the appropriate voltage on your power supply (red wire if using 5V LEDs, yellow wire if using 12V LEDs).
rtkiii
« Reply #11 on: March 22, 2013, 09:42:54 am »
Yeah I have 13 LED buttons already wired and working on the board..thought the LEDs in the coin return might be different.
rtkiii
« Reply #12 on: April 18, 2013, 07:25:08 am »
My new Bulbs came in for the "LEDs" in the coin slots and I cannot get either ones to light.  I guess I'll recheck my cabling from the PACLED to the LEDs.  All other 13 lights work fine.  Is there anything else I could be missing.  I assume they hook up just like the push buttons do, right?
« Reply #13 on: April 18, 2013, 08:36:59 am »
What type are they? Got a pic of the bulb and/or socket?
rtkiii
« Reply #14 on: April 18, 2013, 12:13:18 pm »
Not at the moment but they take the 555 Bulb.  Simple two prong casing.  But I can take a picture today or tomorrow and post it.
« Reply #15 on: April 18, 2013, 12:17:36 pm »
Take the bulbs out, turn them 180 degrees, and reinstall.
rtkiii
« Reply #16 on: April 21, 2013, 09:20:37 pm »
That did not help as they can only be inserted in one way.  Here are some pictures.
Even though this is a new bulb there appears to be some sticky residue on the edges of the bulb now, it seems higher up on the plastic casing but I wonder if something is gucked up inside the contacts...but it happens on both sockets or whatever you call them.  I also open up my cab and checked wiring and also tested with a known good ground/cable to PACLED that I use for my "Start" button and the LED still would not light.
« Reply #17 on: April 21, 2013, 09:47:24 pm »
That's not an LED bulb, that's an incandescent bulb. LED controllers can't light incandescent bulbs.
rtkiii
« Reply #18 on: April 22, 2013, 06:58:21 am »
OH!   :)  Ok thanks.  any suggestions for LED bulbs that would work?  would I need to get a new Bulb and connector(whatever it is called?)
Thanks again
« Reply #19 on: April 22, 2013, 09:33:20 am »
There are plenty of 555 LED bulbs.  Mostly geared towards pinball but they're the same 555 type you are looking at here.
I would suggest either PinballLife.com or PinballBulbs.com.  I have used both and recommend either.
« Reply #20 on: April 22, 2013, 10:00:24 am »
rtkiii
« Reply #21 on: April 22, 2013, 10:19:49 am »
Also, Paradise Arcade Shop.
So this bulb will work with the bulb socket I have I took a picture of?
« Reply #22 on: April 22, 2013, 02:37:50 pm »
Yeah.
rtkiii
« Reply #23 on: April 22, 2013, 03:57:39 pm »
Yeah.
Cool thanks...checked out the site.  Shipping is crazy but still under $10 for everything.  thanks again for your help.
rtkiii
« Reply #24 on: December 03, 2013, 09:41:51 am »
Wait re-read this post...I think I just need to buy the damn bulbs  :)
Ordered from Paradise Arcade.
Posted this earlier today
Been ages since I worked on the Cab(just been playing) and I want to get those lights working.  But before I order I have a really dumb question.  If the IPAC will not power the bulbs how do I get power to the bulbs if there is no external power going into the until any longer.  I gutted it and installed a PC.
thanks,
Rich
« Last Edit: December 03, 2013, 09:53:32 am by rtkiii »
