Okay i've updated the design/color to show each part clearer, the tubes will be semi transparent enough to allow light from RGB leds to shine through.
The 7 metal trims around the outside are there to hide the joins in the plastic and for show
The pc is a HP touchsmart q1105, touchscreen works well, spec is high enough for what it needs to do (run XBMC)
I am running the re-touched skin, which will allow users to run videos of Vevo, and access loads of digital radio stations.
The chrome control panel will have a griffen powermate, a digital display (not sure what i,m putting on it yet and some buttons, power/radio/lights/etc)
The subwoofer will be on the base pointing downwards with a neon ring, placement of the 2 speakers is undecided at the moment.
