February 24, 2026, 04:29:24 am
I finished the whole set of artwork (marquee, CP and both sides). I'm very happy with the result. Especially since I had zero experience with Adobe Illustrator when I started... I will prepare for printing now (adding some bleed, flatten all layers, final check on dimensions) and send it to GameOnGrafics
I was thinking more of the "fold it over the edge and trim at the t-molding slot" method where the t-molding holds down the edge. Scott
Quote from: EMDB on December 17, 2013, 01:43:37 amI finished the whole set of artwork (marquee, CP and both sides). I'm very happy with the result. Especially since I had zero experience with Adobe Illustrator when I started...I will prepare for printing now (adding some bleed, flatten all layers, final check on dimensions) and send it to GameOnGrafics Don't know how I missed this - but seriously very cool! - where did you find the original character artwork ?
Very pretty, but what's up with the joystick washers?
Looks great! It also looks like the outside half of the outer walls (outside the t-slot) is a different colour. Did you end up opting for the heat and fold method for the side artwork?
I think you'll find the difference between your molding is 'Bright Red' and 'Red', your top one being bright red. T-molding.com don't do a Bright Red in 5/8" I don't think. Only standard red (matt)
I've NEVER seen a marquee retainer look good in any color other than black.
With the wallpaper edge guards, you can paint them any color you want. AJ
Quote from: mcseforsale on April 01, 2014, 03:52:07 pmWith the wallpaper edge guards, you can paint them any color you want. AJThanks but I keep them black (as they are intended).
I mounted the t-molding on the CP. I'm not sure how to fixate the corners though. There is quite some tension. Maybe I will glue them:
Oh man i just love your cabinet! It's just awesome!are you going to put plexi on top of your cp? Or you just leave it on the stickers?
Diameter and Cutting Length on flush bit please.
i have one box if ya pay shipping is yours
