Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 901594 times)
  • Last login:July 23, 2025, 07:04:20 pm
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #640 on: August 24, 2013, 02:48:11 pm »
No, no kidneys, just cold, hard, cash... O0
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #641 on: August 24, 2013, 03:33:32 pm »
Damn, I guess next of kin is out of the question too, huh.  ;D
That did turn out great, would not have expected anything less from you.
I have always loved cocktail tables besides cabinets.  They are nice for chill mode & to put your beers on when playing.  :cheers:  another thing to add to my list. ::) ;D
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
« Reply #642 on: August 24, 2013, 04:34:37 pm »
How much for the Midway style cocktail kit?  :applaud:
Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #643 on: August 24, 2013, 04:43:37 pm »
I have to get final pricing from my cnc guy, but it's looking to be under $200 shipped for the melamine kit.
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #644 on: August 24, 2013, 05:05:16 pm »
Haruman, how about one of those red tent nintendo cabs, or some kind of viewlux made the same way? Any plans for some kind of racing cab?
Sent from my SGH-T989 using Tapatalk 2
TKW4rr10r
  • Trade Count: (+16)
« Reply #645 on: August 24, 2013, 06:31:10 pm »
A racing cab? The only way I see a CNC kit for one of those if its styled like an early pole position or spy hunter sit down. A lot of parts would have to be sourced, through. And I'm guessing pretty pricey.
The red tents were all metal, not sure how a wooden one would work out. But the idea intrigues me. Maybe some kind of head-to-head bar-top setup? Maybe even just a stand option for those with one or two bar-tops already?
« Reply #646 on: August 26, 2013, 10:46:09 am »
So, it's confirmed, the midway cocktail kit (woodgrain melamine) will run $200 shipped. 8)
« Reply #647 on: August 26, 2013, 10:49:46 am »
So, New kit designs in progress:
1) Atari cabaret - 80% done
2) mini virtual pin cabinet - 30% done
Other ones in consideration:
Mini-vewlix
Mini-Nintendo
Pedestal
Haven't thought about a racing cab yet... Or a red tent. Let me think about those
  • Last login:Today at 05:27:30 pm
« Reply #648 on: August 26, 2013, 11:08:33 am »
The 'mini-Nintendo' one is a toughy. I've been working on that one myself, and it just doesn't look 'perfect'... It may just be my render, or maybe my measurement conversion is off a bit.
Amazing ideas, as always.
blashyrk
  • Last login:May 14, 2017, 02:56:16 am
« Reply #649 on: August 26, 2013, 12:59:08 pm »
Love the cocktail kit, do you offer international shipping ?
« Reply #650 on: August 26, 2013, 02:01:44 pm »
I can, if you want to PM me with your city, country, and postal code I can tell you how much it would run.
TKW4rr10r
« Reply #651 on: August 26, 2013, 03:09:53 pm »
Mini-vewlix
Mini-Nintendo
Pedestal
NINTENDO BAR-TOP!!!!
Phew, sorry. Killer day at work and had no lunch, a little light headed.  :lol
Can't wait to see the atari cabaret (you got all you needed?). One kit idea that comes to mind that I haven't seen anyone try is the old Nintendo cabaret, ala Donkey Kong:
That would be a cool little kit.
« Reply #652 on: August 27, 2013, 10:47:07 pm »
I think I have all I need. About 90% done. What kind of material are you wanting to make this from?
That other cabaret is pretty sweet, too.
TKW4rr10r
« Reply #653 on: August 28, 2013, 06:19:13 am »
Would this be one sheet of material or two for the atari cab? I'd say the sides should still be 3/4", but you could make the internals, top, bottom, front, and back 1/2" if this requires two sheets and you want to keep cost/weight down. The "internals" sheet could be black and the "sides" sheet could be white.
I'm not sure how you'll have everything laid out on the material, but the finished look for a normal unit would just be the wood paneling on the sides, all other external surfaces black, with internal black or unfinished. If this all fits on one sheet, you could laminate each side differently (one black, one white or wood grain) and just lay them out so they'll still assemble to get the final look.
Man, it looks like  I need to start repairing the boards for my centipede  ;D
« Reply #654 on: August 28, 2013, 11:35:07 am »
It looks like it will take 2 sheets. Problem is, can't fit 2 sides on one sheet, so it will all be 3/4", and it will all be the same material.
I can do a white melamine, or black, or woodgrain... Or if you want something really nice I can do a Baltic birch plywood.
« Reply #655 on: August 28, 2013, 11:50:35 am »
Scratch the Baltic birch, can't get in that size...
  • Last login:Yesterday at 07:15:22 pm
« Reply #656 on: August 28, 2013, 12:02:53 pm »
Too bad, baltic birch is beautiful.
TKW4rr10r
« Reply #657 on: August 28, 2013, 01:16:22 pm »
Let's go with black melamine. It would be easier to prep just the sides (if needed) for the side art, than painting everything else black.
« Reply #658 on: August 28, 2013, 01:26:32 pm »
Sounds good. When my plans are done, I will get an estimate for 3=4" black melamine.
« Reply #659 on: August 28, 2013, 04:18:13 pm »
Ok, take a look.
While the main panels aren't tabbed, their supports are, so that should make construction easier.
« Reply #660 on: August 28, 2013, 04:32:11 pm »
Also included a panel that will convert it to an LCD monitor...
TKW4rr10r
« Reply #661 on: August 28, 2013, 05:44:58 pm »
It looks great! But there a couple pieces missing:
- Control panel bracket sides (2)
- Control panel back brace (1)
- Cardboard surround / bezel mounting strips (2)
- Monitor bracket backing braces (2)   (these do not need to be the full length of the monitor bracket)
None of that needs to be slotted due to variations of what monitors people use.
I made some minor adjustments in the layout you had to make any needed space on the sheets (marked in yellow). Not sure how this works with the CNC, just making suggestions.
Also, didn't see in your graphic if any accommodation was made in the recessed cuts for the marquee or speaker grill.
« Reply #662 on: August 28, 2013, 06:42:40 pm »
Cool.  I did miss the control panel area.  I'll add that stuff in...
The marquee area and speaker area are drawn to those inside dimensions you gave me.
« Reply #663 on: August 28, 2013, 08:15:17 pm »
Is this considered a customer commission? I'm wondering if you'd consider a partnership for Nitz' request? Maybe we figure what the design is worth to you, sell it to Nitz (or me) and have me carve it for Nitz, for Canadian distribution?
Maybe this belonged in a PM? Maybe I'm just being transparent.
:D
TKW4rr10r
« Reply #664 on: August 28, 2013, 08:55:47 pm »
OK, the original has the straight through hole in the smaller dimensions, but require a recess of the larger dimension on the outside face to accommodate the glass and metal grill, I'd say 1/4 deep. Sorry for not making that clear before. I think I got both the inner and outer dimensions in the previous posts :
Maybe this belonged in a PM? Maybe I'm just being transparent. :D
I sure hope this isn't a one-off! I'd hate to see so much work going into something just for me. There should be other people in these forums looking for an Atari cabaret. At the very least I'll order another when I start my Major Havoc build.He's got a dedicated customer in me, until I -eventually- get my own workshop that is ;)
« Reply #665 on: August 28, 2013, 10:18:33 pm »
I'm good for one if I can use a 15 inch CRT in it.
« Reply #666 on: August 28, 2013, 10:46:16 pm »
:D
We can work something out. :-)
« Reply #667 on: August 28, 2013, 10:48:40 pm »
Ah ok, gotcha, I can add a pocket cut to the front no problem.
Yup, not gonna be a one off, will make it available in my store I've it's ready. :))
« Reply #668 on: August 28, 2013, 10:49:58 pm »
I don't see why not
« Reply #669 on: August 28, 2013, 10:51:56 pm »
Put it on my tab, bro.
ron310
  • Last login:July 18, 2016, 06:30:13 pm
« Reply #670 on: August 29, 2013, 06:33:26 pm »
What is the width of that MVS bartop?
« Reply #671 on: August 29, 2013, 06:46:03 pm »
Same as the standard bartop, so ~18.82" wide, control panel is 17.72" wide.
« Reply #672 on: August 30, 2013, 03:10:11 pm »
Oooh
« Reply #673 on: August 30, 2013, 03:15:41 pm »
Oooh
Woodgrain is sooooo 80's. (...and that ain't bad.)
:D
« Reply #674 on: August 30, 2013, 03:32:51 pm »
Love woodgrain!
ghostrider
  • Last login:October 16, 2017, 08:29:47 pm
« Reply #675 on: August 30, 2013, 09:18:43 pm »
Is there any way you could build a kit for the Little Ms. Pac-man (http://forum.arcadecontrols.com/index.php/topic,128666.0.html) that Griffindodd (aka Maximus) designed and make it fit the asus 23" evo monitor?  I would be down for one of those for sure.
particlematt
  • Newbie
  • Last login:October 04, 2013, 03:52:21 pm
« Reply #676 on: August 31, 2013, 09:15:18 am »
I wanted to say I'm glad and appreciative you're doing this for people like me who want a bartop but aren't in a situation to do the woodwork.
Mini vewlix would be a super rad addition.
rablack97
