Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1047127 times)
0 Members and 8 Guests are viewing this topic.
XNIF
  • Last login:January 18, 2017, 04:40:32 pm
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #600 on: August 15, 2013, 01:37:22 pm »
@Floriske this is starting to look very promising :) I just hope that lowering the adminbuttons won't affect the cabinets aesthetics because it breaks symmetry on the frontside admin panel.
floriske.nl
« Reply #601 on: August 15, 2013, 01:48:31 pm »
That's a choice everyone has to make for themselves of course. I just added the ability, not forcing anyone to use it  ;)
« Last Edit: August 15, 2013, 02:58:30 pm by floriske.nl »
  • Last login:February 22, 2026, 06:49:16 pm
« Reply #602 on: August 16, 2013, 09:52:49 am »
Thanks for the measurements, very helpful
« Reply #603 on: August 16, 2013, 09:54:24 am »
Floriske, looking good, man. I like it
floriske.nl
« Reply #604 on: August 18, 2013, 04:52:29 am »
After making some minor tweaks to the design I routed a first "test" version yesterday and it turned out 100%. Everything fits like a glove  ;D
And a picture I took to give you an idea of the size of my evo XR cade:
« Reply #605 on: August 18, 2013, 07:52:07 am »
Shut. The. Blankity-blank. Up.
 :notworthy:
steved61
  • Last login:October 19, 2025, 01:05:53 pm
« Reply #606 on: August 18, 2013, 12:31:23 pm »
New Control Panel made for me by HaRuMaN. looks great can't wait to get it. Great man to work with and a good price for quality work.
Thanks again.
Steved61
« Reply #607 on: August 18, 2013, 01:14:21 pm »
floriske.nl
« Reply #608 on: August 18, 2013, 04:03:51 pm »
 :notworthy:
Hey! Be nice to me will ya  :laugh2:
@steved61 & HaRuMan: looking good indeed!
TKW4rr10r
  • Trade Count: (+16)
« Reply #609 on: August 18, 2013, 04:50:11 pm »
Thanks again.
Steved61
Nice! But what's the cut-out for right above what I assume is a 3" trackball, to the left of a pair of buttons?
steved61
« Reply #610 on: August 18, 2013, 05:10:55 pm »
TurboTwist High-Low™ Push-Pull Arcade Spinner Control from GGG.
Steved61
floriske.nl
« Reply #611 on: August 19, 2013, 10:31:10 am »
Since my first test version turned out to be ok I've converted it to a first release version, see attached.
Since I work with Adobe Illustrator instead of CAD software I created a PDF instead of a DXF. Illustrator DXF's are unreliable.
The files are based on my own machine with 60x93,5cm work area.
Big thanks to degenatrons and HaRuMan!
As they stated before: This is an open-source project. Feel free to download the plans and modify them for you own use as you see fit. By downloading the plans, you are agreeing to the Creative Commons BY-SA 3.0 licensing, found here:
http://creativecommons.org/licenses/by-sa/3.0/us/
« Reply #612 on: August 19, 2013, 03:26:41 pm »
So I'm making good progress on the cabaret... Question is, how do you want to handle the monitor, and how do you want to handle the control panel?
TKW4rr10r
« Reply #613 on: August 19, 2013, 05:44:02 pm »
I have more measurements, I just have to get back to the office where I have the cabaret (work is a little nuts atm). I can tell you already the top panel is just one piece with a taper cut on both ends. The holes for the speaker grill, marquee and coin door require rounded corners.
I'll provide detail pics and measurements for the monitor mounting board. took a lot of pics of the surrounding areas to showing how it all fits together. I have a control panel, but if you wanted to make something to give anyone else the option for a wooden one, I can take some measurements. I could probably trace a profile and scan/send it to you if that will help.
I know the holes for the coin door and speaker appear to be straight through. The marquee's original measurements are for a recess, with the full hole I'd say .25" smaller on all sides. I'm having a tough time removing the speaker grill and marquee if anyone knows the trick. The screws look like stripped torx or maybe deigned to be similar to rivets.
« Reply #614 on: August 19, 2013, 06:29:58 pm »
I received these images from a guy on Reddit, after I asked for some input.
Hoping this may help in some way!
TKW4rr10r
« Reply #615 on: August 19, 2013, 10:37:52 pm »
For the side panels, the original sketch model had those spot on, you have to get all the arcs and curves right. Not knocking his measurements, but they can be off depending on where you measure in the arcs.
As far as the front is concerned, I explained the measurements in a previous post. The actual panel extends into the CP area and the holes for the speaker grill and marquee are a little more complex. I'll add some notes to add to the previous measurements and post some related photos in the AM. Did he mention which cab these came from?
« Reply #616 on: August 19, 2013, 10:41:50 pm »
I traced the sides directly from sketchup.
TKW4rr10r
« Reply #617 on: August 19, 2013, 10:54:14 pm »
Some notes (will update with pics tomorrow):
Top panel:
- bevel cut on both ends, sits flush to back of cab
- 1.25" below top of side panels
- top face measures 19" W x 22.5" L
- same angle to bevel as top of side panels
To add to the previous post I made about the front panel:
- Speaker grill inner facing hole is 4"W x 7"H. Outer facing side is the 5"Wx8"H
- Marquee inner facing hole is 15.25"W x 3.25"H, outer facing side is 16.5"W x 4.5"H
- small radius corners on speaker grill and marquee
- Coin door remains 7.5" W x x20" H
- larger radius corners for coin door.
Monitor mounting board:
- Total size is 19" W x 23.5" H
- Inner cut out hole measures 15.5" W x 18.5" H
- Inner cut out centered, with 1.75" on either side and also from top of panel.
- Mounting holes for monitor are 5" from each side and 19.5" apart vertically
- Shape accommodates mounting strips from adjacent panels, and is mounted 9.5" back from front edge of top panel.
Bottom panel:
- My cabinet is a little water damaged here, but it seems to be 19"W x 27" L. Once all the other corresponding measurements are done your model should be able to verify.
I guess my next question is, will this be designed to assemble just like the original, with  .75" x .75" strips to mount the panels, or with the same "pocket" design like the other projects here? Pocket design would make for a cleaner, less complicated build. But strength is a concern. Just curious.
« Last Edit: August 20, 2013, 01:33:48 pm by TKW4rr10r »
« Reply #618 on: August 19, 2013, 11:21:30 pm »
I thought about doing pockets, the problem is the sides are flush with the front and back panels, leaving no room for pockets... I could change the design to make it not flush, but then it would not look the same.
« Reply #619 on: August 20, 2013, 01:09:15 pm »
Just an fyi, I ended up with an extra MVS kit on hand, so if anyone is interested, I can get it out to you pretty quick.
TKW4rr10r
« Reply #620 on: August 20, 2013, 01:35:44 pm »
Some quick pics before I have to head out on the road again:
TKW4rr10r
« Reply #621 on: August 21, 2013, 06:11:20 pm »
OK, some more measurements, this time using some good shots of a partially deconstructed cab from an old post in another forum.
This is a tempest cabaret, and I choose to show this for it's differences:
Please note the items circled in red. This piece is not in my cabinet and appears to never have been part of it's construction. I believe it to be the lighting mounting plate for the marquee, since the centipedes never had that as an option. Personally, I wouldn't need it, since I have better options for lighting than original, but maybe a single board for the option would not be a bad idea. would add strength to the cab, as well.
Here is what I heard about the tempest and other cabarets with vector tubes having additional venting for the heat they produce. That is the upper rear panel. My centipede is to the right. I think the standard kit should include the panel from the tempest cab instead.
PLEASE let me know if you need any further measurements. As far as construction, I would try for partially pocketed like your other designs, the top, monitor board, and anything else with the exception of front and back panels could be done this way, even some of the blocking strips could be pocketed for added strength. Hope these are helpful in completing your model.
« Reply #622 on: August 21, 2013, 06:47:48 pm »
very helpful, thank you...
floriske.nl
« Reply #623 on: August 23, 2013, 08:29:52 am »
Shot a short video of mounting the base of the kit (without glue):
« Reply #624 on: August 23, 2013, 02:06:09 pm »
Uh-oh.. What do I have here?
« Reply #625 on: August 23, 2013, 02:08:09 pm »
You know, if MY CNC GUY would get back to me with better pricing... ...I still wouldn't be able to compete with your build quality. It looks perfect, man! I can't wait to see the assembly pics! (How many sheets - and of what size - did it take to carve?)
« Reply #626 on: August 23, 2013, 02:16:20 pm »
Yeah my cnc guy can make some excellent stuff, for sure!
That was exactly one sheet of 1/2" cherry melamine.
I've got someone working on metal control panels and vents for me, should get them Monday.
The top matches the midway exactly, so existing replacement tempered glass or Plexiglas cab be used...
« Reply #627 on: August 23, 2013, 02:53:58 pm »
Flat pack for PBJ?
« Reply #628 on: August 23, 2013, 02:57:08 pm »
It's too bad PBJ didn't live to see this day.
« Reply #629 on: August 23, 2013, 03:01:56 pm »
Haha, yeah, he was dying for a cheaper midway cocktail kit, wasn't he?
Other side:
« Reply #630 on: August 23, 2013, 03:04:31 pm »
I'm sorry, but I couldn't resist.
Whatever did happen with Pinball Jim, anyway? I've seen the references to him leaving everywhere, but never did find post outlining the root cause. He was still here when I went on hiatus, myself.
(Sorry Haruman. Didn't mean to derail your work!)
« Reply #631 on: August 23, 2013, 03:51:42 pm »
The story is kind of sketchy, but it seems to involve U.S. Marshalls, a Konkey Dong flyer, a one-armed man, and $50 cash-in-hand.
« Reply #632 on: August 23, 2013, 03:52:56 pm »
I thought you were your own CNC Music Factory guy?
TKW4rr10r
« Reply #633 on: August 23, 2013, 04:29:32 pm »
Can't wait to see completed pics. What's this "alternative to coin door" reference on your site about this kit, anyway?
Re: Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #634 on: August 23, 2013, 05:45:33 pm »
It'll just be a piece of sheet metal, designed to fit over that opening, with a couple of holes as credit buttons, should be pretty cheap compared to a coin door.
« Reply #635 on: August 23, 2013, 05:46:09 pm »
Parts laid out:
« Reply #636 on: August 23, 2013, 05:47:08 pm »
Dry fit, no glue:
« Reply #637 on: August 23, 2013, 05:47:54 pm »
Still dry fit, no glue...
« Reply #638 on: August 23, 2013, 05:52:14 pm »
Not yet. I'm in the design phase right now. When I have my outbuilding built, then I will have my own CNC machine.
That is one sexy looking box. Nice.
tron84
  • Last login:November 15, 2017, 06:45:56 am
« Reply #639 on: August 24, 2013, 09:46:02 am »
She is PRETTY, that is sweet!!!!!! :applaud: :applaud: :cheers:
Looking Good, Mr. Carter!!!!! Nice..... :applaud: :applaud:
You just want all my $$$$ huh  :lol :lol :lol
you take kidneys by chance too?  :lol
« Last Edit: August 24, 2013, 09:48:50 am by tron84 »
