Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 978434 times)
0 Members and 7 Guests are viewing this topic.
  • Last login:December 02, 2025, 03:23:14 pm
« on: February 18, 2013, 10:46:13 am »
http://www.haruman.com/
1/2" Black melamine, simple constuction, blank or pre-cut admin and control panels.
No painting or sanding required!  Just assemble and go!
Big thanks to degenatrons for the original CNC file that I have working from and modifying.  This is an open-source project, by the way.  Feel free to take the plans and modify them for you own use as you see fit.  By taking the plans, you are agreeing to the Creative Commons BY-SA 3.0 licensing, found here:
http://creativecommons.org/licenses/by-sa/3.0/us/
Here is my current revision of the CNC plans:
https://docs.google.com/file/d/0B7Rqi_4oIj-wbDVtaWlLQ1NTQk0/edit?usp=sharing
Here is the widescreen version:
https://drive.google.com/open?id=0B7Rqi_4oIj-weFlwQ05NekFlRkE
Here is the link to the open source / open hardware project run by degenatrons:
http://kadevice.tk/forum/viewtopic.php?f=51&t=305&p=1364#p1364
« Last Edit: August 09, 2024, 10:08:21 am by HaRuMaN »
Re: CNC cut Weecade Kits - Ships to continental US
« Reply #1 on: February 18, 2013, 10:46:30 am »
Specs:
Hardware:
Fits a Horizontal 17" 4:3 LCD monitor nicely.  Can fit a Horizontal 19" 4:3 LCD, but it's tight.  17" is the recommended size.
With a 17" monitor, a microATX motherboard, ATX power supply, and standard 3.5" hard drive fit.
Control and Admin Panels:
Comes in 2 options, drilled or undrilled.
Drilled has a standard 6 button Street Fighter layout, with 2 buttons for start and coin.  Admin panel has 3 buttons drilled.  Hole sizes are 1.15" diameter and will fit Happ buttons.
If you want a different layout, order the undrilled.  I have found that a 2 player 6-button layout MAY fit, but would be very cramped.  2 player 4-button is less so.
Control panel dimensions are: 17.72" X 6.19"
Monitor mount panel:
Drilled for both 75 X 75 and 100 X 100 VESA mounts
Speaker Panel:
Drilled holes for 2 speakers, hole pattern is 3.79" in diameter.
Overall Dimensions:
Height: 21.43"
Depth: 18.6"
Width: 18.72"
Weight:
Melamine kit only: ~21 lbs
« Last Edit: February 19, 2013, 09:04:03 am by HaRuMaN »
« Reply #2 on: February 18, 2013, 10:46:41 am »
Pics of kit pieces:
« Last Edit: February 25, 2013, 09:03:22 am by HaRuMaN »
« Reply #3 on: February 18, 2013, 10:46:53 am »
Basic assembly instructions:
Lay out one side flat, pocket cuts up:
Fill each of the five 1/4" deep pockets with a liberal amount of wood glue.  Don't be stingy.  Insert each of the tabbed panels into the deep pockets:
Place the other side on top (with NO glue yet), aligning the tabs into the slots:
Place a heavy weight on top, wipe up the excess glue with a damp paper towel.  Wait for an hour or so.
After the hour or so has passed, take the weight off the cabinet, and carefully remove the unglued side.  Place the unglued side down, fill the five 1/4" pockets with a liberal amount of glue, and carefully guide the tabs into place.  Again, set a weight on the assembled cabinet, wipe up the excess glue with a wet paper towel, and leave for ~24 hours in a warm place.
Couple of other views:
Once completed and dry, lay the bartop face down (marquee & control panel area closest to the ground).
Once down, place the plexiglass inside, one side will rest on the back of the speaker panel, the other side will rest on the batons for the control panel.
Attach the monitor to the VESA mount panel using M4-.07 machine screws (25mm length).  Place the monitor & panel inside the bartop resting on the plexiglass.  Adjust the placement so the monitor is visible.  Use the included angle brackets to attach the panel to the inside of the cabinet.
* NOTE : The included screws with the brackets are a little too long and will poke out of the cabinet if you use them as is.  You either need shorter screws or use some spacers (like washers).
Usually the monitor is enough to hold the bezel plexiglass in place.
For the marquee plexiglass, you can find aliminum L channel at Home depot, cut to size, and paint.  There are also places online that stock black plastic L channel.  You will need a piece for top and bottom.
« Last Edit: August 02, 2013, 11:43:02 am by HaRuMaN »
« Reply #4 on: February 18, 2013, 11:20:04 am »
I have a version 1.0 and it was pretty good, this is version 2.0 and seems a ton better. I have done a lot of business with Haruman and I have never had a bad transaction yet.
« Reply #5 on: February 18, 2013, 11:23:13 am »
Thanks for that.
« Last Edit: November 13, 2014, 04:10:52 pm by HaRuMaN »
  • Last login:Yesterday at 12:47:05 am
« Reply #6 on: February 18, 2013, 11:49:51 am »
HaRuMaN has hooked me up with V1 and V2 (pickup tomorrow  :gobama). Super trustworthy. I know the work that goes in to getting these done, sorting the parts, packing them up, and shipping them out, and this is totally worth it.
« Reply #7 on: February 18, 2013, 12:03:25 pm »
Seems like a real good price.
« Reply #8 on: February 18, 2013, 12:08:05 pm »
Thanks.  I had to hunt around for a CNC service that were reasonable, the first two I contacted wanted between $200 & $250.  That almost killed the project dead in the water.  Glad I kept looking, though.
yaksplat
    • Random Projects
« Reply #9 on: February 18, 2013, 01:10:11 pm »
So if you put all of the profits into building your own CNC, you could really be on to something....
http://yaksplat.wordpress.com
« Reply #10 on: February 18, 2013, 01:11:31 pm »
The thought HAS crossed my mind, to be sure.
yaksplat
    • Random Projects
« Reply #11 on: February 18, 2013, 02:29:43 pm »
I officially financed my entire cabinet build this way.  It completely improves the wife acceptance factor.
Ginsu Victim
  • Comanche, OK -- USA
« Reply #12 on: February 18, 2013, 08:57:34 pm »
Pics coming soon.
WHEN?!??!?
Sorry, I just really want to see what you're up to.  ;D
I like the price and your work has always been excellent.
ghostrider
  • Last login:October 16, 2017, 08:29:47 pm
« Reply #13 on: February 18, 2013, 10:14:12 pm »
Interesting, cant wait to see pics.
What size screen do you plan to accommodate?
Vertical or Horizontal?
Any Custom options (control panel, larger screens, etc.)?
404
« Reply #14 on: February 18, 2013, 10:55:44 pm »
very interested. have so many questions
are custom sizes available or would they be just one size?
how wide, high, deep are they?
what kind of screen range would you have with this kit?
what kind of board options would it support? itx, matx, atx etc
what kind of buttons would it support
single player or two player?
« Reply #15 on: February 19, 2013, 09:04:37 am »
Please see second post for more details, I just updated it.
« Reply #16 on: February 19, 2013, 09:53:54 am »
At the very least it's a way to get yourself a free CNC machine....
...if you could just manufacture the free time to build one.
« Reply #17 on: February 19, 2013, 09:57:07 am »
Could always get my CNC guy to cut the CNC parts for me...
"Hey, what are you making with this?"
"Nuffin..."   >:D
« Reply #18 on: February 19, 2013, 09:59:06 am »
You could pay those dumpster divers extra to load it in your machine, too!  :cheers:
gonzo90017
« Reply #19 on: February 19, 2013, 07:45:34 pm »
Can't wait to see some pics.
  • Last login:Today at 05:55:35 am
« Reply #20 on: February 19, 2013, 09:07:27 pm »
You could always ask Yvan256 if he'll share his files.
The individual pieces parts look so unassuming.  >:D
« Reply #21 on: February 19, 2013, 11:12:10 pm »
Yeah, PL1 is right, just tell them they're artistic coasters...   :laugh2:
« Reply #22 on: February 21, 2013, 11:04:20 am »
Updated 3rd post with kit pictures, next I will get some assembly photos as I put it together.
jmike
« Reply #23 on: February 21, 2013, 12:22:07 pm »
Wow! These look great. Can't wait to see one put together.
I've bought several arcade related parts from HaRuMaN in the past, he's very reliable and highly recommended.
« Reply #24 on: February 21, 2013, 12:23:27 pm »
Thanks!  :cheers:
Ginsu Victim
« Reply #25 on: February 21, 2013, 03:31:55 pm »
I like what I see. Any chance of a picture showing it assembled?
« Reply #26 on: February 21, 2013, 03:33:02 pm »
Yes, going to assemble this one soon, I'll be taking pictures of the process.
Ginsu Victim
« Reply #27 on: February 21, 2013, 03:55:11 pm »
Dance, monkey, dance! Do our bidding!
« Reply #28 on: February 21, 2013, 04:06:32 pm »
Lol, for a sneak preview, you can look here:
http://forum.arcadecontrols.com/index.php/topic,124529.msg1335152.html#msg1335152
Imagine it in sexy black melamine, and without the batons.
« Reply #29 on: February 21, 2013, 05:47:01 pm »
no batons? That was my is a brilliant idea!
  • Last login:Yesterday at 03:15:03 pm
« Reply #30 on: February 21, 2013, 05:59:41 pm »
I put together two version 1 kits. They were good and the transaction was flawless.
WOULD BUY AGAIN!!!!!!!!!!!!!!!!!!!!!
northerngames
  • Trade Count: (+18)
« Reply #31 on: February 21, 2013, 06:21:05 pm »
I know your just getting into these but is any of the sideart guys lurking around jumping in to get some custom direct fit artwork going on for these or is there already something like that out there for them already?
j2obin
  • Last login:March 12, 2015, 02:10:20 pm
« Reply #32 on: February 21, 2013, 06:39:25 pm »
Taking orders?
« Reply #33 on: February 21, 2013, 08:32:48 pm »
Almost ready to take orders, will probably do so starting sometime next week.
Ginsu Victim
« Reply #34 on: February 21, 2013, 09:45:50 pm »
You planning on doing this for a while? I may not be able to place an order until August or September.
« Reply #35 on: February 22, 2013, 08:35:07 am »
Yeah, my CNC guy is fine with smaller runs, too.  As long as he doesn't close up shop (which it doesn't look like he will, he's always busy), I should still be doing this.
jammin0
« Reply #36 on: February 22, 2013, 03:37:26 pm »
These look sweet.  So . . . batons on the CP, and have you done the VESA mount yet?  I'm assuming you would screw in batons and then glue to that?
I can't wait to see people start making these.  I might have to order one or two when I sell something to generate some cash.  Love the finish.
« Reply #37 on: February 22, 2013, 03:53:34 pm »
There are fatter batons for the monitor mount.  It's up to the user on where to mount it (due to varying monitor sizes, etc).  I forgot to show the batons in the first set of pics, I'll through them up later.
bamaholic
  • Last login:November 06, 2016, 08:33:37 pm
« Reply #38 on: February 22, 2013, 04:39:51 pm »
I'm going to jump on the bandwagon and say this kit looks awesome. I'm always looking for a new project and this may be it.
Goz
  • KOTA
« Reply #39 on: February 22, 2013, 09:22:24 pm »
I can post a pic of my mostly assembled V1 I am planning on wiring controls tomorrow and setting some more of it up.
