Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1028947 times)
piensken1
  • Last login:June 25, 2019, 07:51:57 am
Re: CNC Cut Bartop Kits - Orders Open! New Models Available!
« Reply #2560 on: October 18, 2018, 09:00:12 am »
can you also send them to me?
If you want ill pay for it :)
Also, what ae the small pices on the image? do we need them for installing?
« Reply #2561 on: October 18, 2018, 09:24:58 am »
PM me your email.
Those are the batons for the control panel and back door, and yes, they are needed.
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #2562 on: October 26, 2018, 05:55:00 pm »
Curious if you have any pictures of the EVO Mini other than the render.  Also is there any type of monitor mount or did you just keep the stand on the 11 inch monitor and use it?
« Reply #2563 on: October 26, 2018, 06:12:51 pm »
There is a mount in the kit that works with the EYOYO monitor it is designed for.
« Reply #2564 on: October 26, 2018, 06:34:34 pm »
Not to tute my own horn, but I do good work
stephenp1983
« Reply #2565 on: October 27, 2018, 01:50:23 pm »
Thanks for posting the images.  I agree very nice work!
stephenp1983
« Reply #2566 on: November 21, 2018, 09:18:33 am »
Just placed an order for the mini evo.  Would you happen to have any AI or PS type templates for the pieces that I could use for artwork?  Order number is 534 if you need it.
« Reply #2567 on: November 21, 2018, 09:23:50 am »
I will send you what I have later today.   :cheers:  Thanks!
stephenp1983
« Reply #2568 on: November 21, 2018, 01:35:26 pm »
Thanks I appreciate it!
dluusional
  • Last login:February 09, 2019, 06:13:28 pm
« Reply #2569 on: November 25, 2018, 12:42:44 pm »
Hi Haruman,
I sent you an email via your web store on Thursday regarding the Evo XR 2, I was wondering if you had a change to read it yet.
Edit - sorry, seems your email fell into the spam folder. thanks for your response
« Last Edit: November 29, 2018, 12:02:39 pm by dluusional »
stephenp1983
« Reply #2570 on: December 01, 2018, 01:32:22 pm »
Just wanted to see if you had a chance to get the templates for the mini yet. No rush just checking :)
« Reply #2571 on: December 01, 2018, 01:39:21 pm »
Sorry.  Email me and I'll reply with the templates.
stephenp1983
« Reply #2572 on: December 01, 2018, 08:07:29 pm »
NP at all just sent you an email, thanks again.
negative1
  • Last login:Yesterday at 02:33:31 am
« Reply #2573 on: December 26, 2018, 04:47:14 pm »
I don't see a post for the Cocktail cabinet kits. I guess I'll post it here.
Sent a PM with message, and emailed site also.
Kirmus
  • Last login:December 29, 2018, 07:06:31 pm
« Reply #2574 on: December 29, 2018, 07:02:20 pm »
Hey All,
In the process (finally!) of figuring out my first bartop arcade machine.  From reading through the thread I answered a lot of my questions with using the plans on the first page though what I'm not sure on how to setup my tool paths to run.  I understand the part about cutting pockets for the yellow/red in the file but for the outside edges, I assume the bit follows the line directly as opposed to an inside/outside offset.  If that's the case, what size bit should be used?  I don't either eat away to much material with a bigger bit or leave extra by using a smaller bit.  And looking at the file, I guess I would ask the same of the button holes.  Should they be cut following the line directly?  It wouldn't make sense to cut these as pockets but wanted to verify first.
If anyone is interested, using a Shapeoko XXL and Carbide Create.
negative1
« Reply #2575 on: January 02, 2019, 08:46:10 pm »
Happy New Year,
Lee, get back to me about the cocktail unit.
I'm still interested in ordering it.
later
-1
stephenp1983
« Reply #2576 on: January 13, 2019, 02:06:36 pm »
Got my order for the EVO mini right before Christmas and the kit looks great. Just now having time to start working on it and was curious if you had assembly instructions for it like you do some of the other kits on your site.   Thanks!
« Reply #2577 on: January 13, 2019, 02:14:50 pm »
Not yet.  A few tips though and it will be super easy:
1) Dry fit everything before gluing to make sure you know where it goes
2) Mount your monitor to the monitor mount board before gluing (the monitor mount gets glued in this kit)
3) Mount your speakers (if any, I just used the monitor speakers for my build of this kit) before gluing.
On this kit, the bottom is detachable, it will will connect to small batons on the bottom of the sides, I usually use industrial velcro to hold the bottom on.
negative1
« Reply #2578 on: January 16, 2019, 10:05:33 pm »
Can you use nails, and screws for added support, instead of just glue.
This is referring to the cocktail cabinet kit.
later
-1
« Reply #2579 on: January 16, 2019, 10:09:13 pm »
later
-1
Not needed, but yes, you could add blocks internally and screw them in.
Sent from my Moto E (4) Plus using Tapatalk
negative1
« Reply #2580 on: January 18, 2019, 01:39:10 pm »
later
-1
Good, I'm not a fan of glue.
Do you still have any cocktail kits.
I guess I'll worry about the controls later. Maybe you can send my blank panel,
and I'll drill the holes myself. Also, maybe I can extend the panels to be longer,
so the controls I wanted can fit properly.
later
-1
  • Last login:Yesterday at 07:47:22 am
« Reply #2581 on: January 18, 2019, 01:51:11 pm »
A wood glue joint is stronger than nails and screws.
negative1
« Reply #2582 on: January 19, 2019, 04:21:22 pm »
True, but it's not easy to disassemble or take apart later on.
later
-1
« Reply #2583 on: January 19, 2019, 05:24:49 pm »
That is absolutely true, but the question didn't mention disassembly.
negative1
« Reply #2584 on: January 19, 2019, 11:42:53 pm »
I've owned 2 original cocktail tables before, and they were a pain in the neck to move,
and to do anything with.
I just gave them away when I finally moved.
even though I'm in a house now, and have plenty of room, if I ever do have to move,
I'd rather be able to take things apart when the time comes.
later
-1
MBaran
  • Last login:December 29, 2020, 08:34:56 pm
« Reply #2585 on: January 29, 2019, 03:59:01 pm »
for those with an Evo XR 2, is there sufficient ability to cool using a few PC case fans mounted along the rear holes of the back panel?
Erzak
  • Last login:August 23, 2021, 03:47:45 pm
  • First cabinet complete, now about that software...
« Reply #2586 on: March 14, 2019, 06:06:21 pm »
What the (assembled) dimensions of the Evo Mini cabinet?  Guessing it's ~8-9 inches wide based on the monitor width?
« Reply #2587 on: March 14, 2019, 06:08:03 pm »
Approximately 19.3" Tall, 16.5" Deep, and 13.4" Wide
The control panel adds width. Internal width is 10.5" off the top of my head.
Doublegrg
  • Last login:October 31, 2019, 11:39:07 am
« Reply #2588 on: April 04, 2019, 12:45:20 pm »
It's about time I posted some pics of my (nearly) completed Haruman Bartop.  I went with an NHL 94 theme.
did you end up selling this? sent you a msg on the 94 forum
rtkiii
  • Last login:May 07, 2024, 04:42:35 pm
  • Ready to Build! Not building? Making Movies!
    • RTKIII Productions YouTube Channel
« Reply #2589 on: April 15, 2019, 04:17:25 pm »
Any plans to do a pedestal setup?
« Reply #2590 on: April 20, 2019, 12:44:12 am »
Here's a video of my completed Ms. Pac-Man themed Golden Age Bartop.
DeL
Sent from my moto z3 using Tapatalk
dustinf36
  • Last login:March 16, 2025, 06:25:18 pm
« Reply #2591 on: August 24, 2019, 12:03:19 am »
Hey HaRuMaN, I am wanting to talk to you about a custom panel but cant send a PM. Do you have another way I can contact you?
  • Last login:Today at 04:52:49 am
« Reply #2592 on: August 24, 2019, 12:27:17 am »
You can now.   :cheers:
« Reply #2593 on: August 24, 2019, 10:44:35 am »
You can email me at:
haruman@gmail.com
wackocrash5150
  • Last login:October 18, 2019, 03:56:46 pm
« Reply #2594 on: October 11, 2019, 09:43:12 am »
Hi HaRuMaN.
Just wanted to pass on a thanks for sharing your drawings. I was able to cut one out on my cnc after a few modifications.  Mainly because the plan was for 0.5" melamine, whereas at Home Depot here in Canada, it's actually 13mm melamine.  Doesn't sound like much but it causes the pockets to be too small. First time cutting melamine on it too so I learned about how to avoid chip-out. After a few adjustments, I think it turned out pretty well. Attached is a pic of it just dry fit together.
Thanks again.
« Reply #2595 on: October 12, 2019, 06:49:27 pm »
Excellent work!  Looks great!!!   :applaud:
bombfirst885
  • Last login:April 20, 2020, 09:55:53 am
« Reply #2596 on: December 06, 2019, 03:11:11 pm »
I'm curious if you sell plans for your builds? I have a project for school coming up and I want to build a bartop cabinet. I need to build it myself but can get away with using dimensions from someone else. I'm interested in the Degenatron or the ultimate widescreen. I'm confused how to take the links in the OP and transfer those into plans to cut the material. Any help would be greatly appreciated!
Btw I'm new so forgive me if this question has been asked multiple times.
« Last Edit: December 06, 2019, 03:24:45 pm by bombfirst885 »
Mystrandir
  • Last login:February 26, 2021, 04:13:09 pm
« Reply #2597 on: April 20, 2020, 03:29:34 pm »
Just wanted to drop a couple pictures of the build I completed using the Minitendo.
« Reply #2598 on: April 20, 2020, 08:34:42 pm »
Looks great!!!
Mystrandir
« Reply #2599 on: April 22, 2020, 02:47:01 pm »
Thanks, the kit made it easy  :) . I expect I'll be in the market for a widescreen in the near future.
