December 15, 2025, 05:16:58 am
0 Members and 9 Guests are viewing this topic.
Quote from: pbj on January 27, 2014, 04:03:01 pmCan you CNC me some DDR squares? They'd need to be 1/8" thick and I need 8 (dimensions are roughly 12x12). Cheap.What material?
Quote from: HaRuMaN on January 27, 2014, 04:05:08 pmQuote from: pbj on January 27, 2014, 04:03:01 pmCan you CNC me some DDR squares? They'd need to be 1/8" thick and I need 8 (dimensions are roughly 12x12). Cheap.What material?Lexan, I guess. Something that's going to withstand my godzilla sized ass stomping on it.
Redesign of the widescreen bartop. Change the side profiles, made it slightly wider to hole a 24" widescreen monitor. Added more space in the bottom, can hold a phat ps3 or 360.
You must pay your artist a ton of money for that kind of work.
I pay him in Harubucks...
Quote from: HaRuMaN on February 11, 2014, 10:53:01 amI pay him in Harubucks...'Tis true. I have $40 HaRuBuCkS saved up. What's the interest rate?
I get 1 Harubuck per complete art set, almost up to a tenner! Rick gave me a virtual high five then took my VESA mount idea
Wow that's beautiful. Description on your site says it's meant for a 17" or 19" horizontal monitor, what's the biggest vertical it could fit? Are the artwork areas (marquee) the same size as a full Nintendo cab or shrunk down?
Marquee is shrunk down to fit the cabinet.
So is anyone offering the artwork for this? I need to get started on my H-Man special soon
So, hang on. Are you offering renders of full-on skinned graphics for everybody's kits now?
So are you making these now, I guess. Very cool , everybody needs a Mario cube How much
Oh get a room you two!
I hope I'm not stepping on your thread HaRuMan - but have you seen these: 8bitlit.comI backed it on Kickstarter and have had it hanging up for a while now. You hit the bottom to turn it on / off and it makes the coin 'da-ding' noise - very cool.
Better design:
Get out of my head! I was just going to PM you that very same edge design idea. Will the top/bottom panels be interchangeable? I'll be in for one, but I'd like to hang it with a light in from above. I'd assume you could use the same whole sizes for that regardless if you were using it as a floor standing lamp or hanging profile.
Next up: 1943: a Tiny Pilot kit!Sides are 3/4" MDF, all other pieces are 1/2" MDF. Should have the estimate back from my CNC guy in a few days.
Quote from: HaRuMaN on December 20, 2013, 10:55:14 amNext up: 1943: a Tiny Pilot kit!Sides are 3/4" MDF, all other pieces are 1/2" MDF. Should have the estimate back from my CNC guy in a few days. Did this happen?
I have a two player Haruman I'm about to assemble. Is there anything you guys recommend doing before I glue it together? I was thinking mounting the speakers would be easier before I glue
