Author Topic: CNC Cut Bartop Kits - Orders Open! New Models Available!  (Read 1029573 times)
lowgunn
  • Last login:February 08, 2025, 02:33:10 pm
Re: CNC cut Weecade Inspired Kits - Ships to continental US - Orders Closed!
« Reply #120 on: April 12, 2013, 12:13:01 pm »
Is that 22" edge to edge or 22" just on the control panel.   Thanks!
« Reply #121 on: April 12, 2013, 12:38:33 pm »
Just on the control panel.
« Reply #122 on: April 12, 2013, 12:40:35 pm »
Just got my kit!
Packaging was nice and tight, no shipping damage on any corners.
Kit contained all the correct pieces showed in the preview.
I'm really looking forward to start building!!
Thanks HaRuMaN  :cheers:
Awesome, thanks for the order!  :applaud:
EvilEmuOfDoom
  • Last login:December 28, 2013, 02:15:11 pm
« Reply #123 on: April 13, 2013, 10:58:22 pm »
Got mine today!  Packed VERY well too, seriously impressed :).  I started putting it together and can't wait to play around with it!  Sadly, my CGA monitor that came in last week or the week before was DOA and had to be sent in for warranty replacement and I don't know when I'm getting it :(.  I plan on using mine as a jamma test bench as well as playing games on it.
Thanks again HaRuMan!  My friend Josh came over while I was starting assembly and really wants one now too ;)
« Reply #124 on: April 16, 2013, 08:25:22 am »
got mine too, perfect condition, excellent packing!
05SRT4
  • Check out my Pow Pow
« Reply #125 on: April 16, 2013, 09:28:15 am »
What PC Specs are you guys going? I'm still not sure what i'm going to put in mine.
« Reply #126 on: April 16, 2013, 09:43:19 am »
no idea yet, might not even run a PC (theres always DC, xbox, 360,etc)
I got it because it was such a great deal and Bonnie's Pink Box turned out so well (version 1.0 kit from Haruman)
sharpfork
    • KADE
« Reply #127 on: April 16, 2013, 10:57:42 am »
I'd love to see some unboxing pics.
« Reply #128 on: April 16, 2013, 11:00:56 am »
I have a boxed pic:
« Reply #129 on: April 16, 2013, 03:01:11 pm »
I only took 1
bzbee
  • Last login:September 19, 2017, 10:16:02 am
« Reply #130 on: April 19, 2013, 08:43:52 pm »
This is awesome! Do you have a waiting list?
sharpfork
    • KADE
« Reply #131 on: April 19, 2013, 08:54:15 pm »
Great packing job!
SIII + Cyanogen + Tapatalk 2
Orders open again.  Also have a new widescreen kit with two players available!  Designed to fit this monitor:
http://www.amazon.com/ASUS-VH236H-23-Inch-Full-HD-Monitor/dp/B002453K5G
I am also working a new design for a vertical kit.   :applaud:
SNAAKE
  • Trade Count: (+29)
booyah! I am getting one too :applaud:
(possibly lot more depending on how things work out for me)
retrostark
  • Last login:February 06, 2017, 03:48:51 pm
  • Indie Dev/Custom Arcade Cabinet Hobbyist
    • RetroStarkCustomCabs.com
am i getting this right you are just selling the wood cut-outs? if so you are smart. people can save a lot of time by using your kit.  :applaud:
Yes, just the wood.  Plexiglass can be included, too.   :cheers:
With the simplified assembly, these kits do save time.
bzbee
I would like to place an order but I'm too new a member to send PMs. EDIT:- Looks like all I needed was 2 posts! PM coming!
« Last Edit: April 25, 2013, 09:51:33 pm by bzbee »
Order received, thanks!  :cheers:
SNAAKE
call the 2 player version WeeWeeCade :lol
Thanks, I just spit my coffee everywhere...   :laugh2:
lordnacho
Think it could fit a Dell 2408WFP?
http://www.amazon.com/Dell-2408WFP-UltraSharp-Widescreen-Definition/dp/B0018LJYFC
22 x 8.2 x 15.6 inches
The Asus is
21.6 x 8.7 x 16.1 inches
Tempted.  I've got enough pc parts gathering dust as well.
The Asus is
Yes, I would think it should.
lordnacho
What size monitor for the vertical?  I've got another spare 19"
And any ETA?
And any ETA?
Still working on the plans for the vertical.  I was planning on 19" being the default size, with a 20.1" being a tight squeeze.  Gonna try to have them drawn up by Monday.
northerngames
  • Trade Count: (+18)
I am looking at a new VW246H as I type, will it fit the same as the VH236H? think I am a inch bigger but monitors are weird like that and may be the exact same.
or do you have dimentions for the 2player setup? if this will fit I wll do the 2 player instead of the original just becuase I have this monitor here that may fit perfect already.
22-1/2" X 13-1/2" X 3"-4" depth
« Last Edit: April 26, 2013, 03:14:02 pm by northerngames »
The 2 player is 22" wide internally...
You maybe could decase it?
northerngames
it is actually 22-1/4" if the screen overlay is all one peice it could probaby be decased and clear the 1/8" on each side as the plastic itself is probably close to that alone.
now sure how it would look in there with no screen bezel and the display butted right up on the sides of the cab though.
Check out Malenko's build using my kit and a 20" 4:3, edge to edge in there:
http://forum.arcadecontrols.com/index.php/topic,131913.msg1354043.html#msg1354043
Messing around with sketchup, gonna make a parts list for each bartop:
I left the bezel on the monitor too
northerngames
mine would have to come off to fit.
I think I will just stick with the 17" instead I want to keep it small anyhow and I would rather have a more squared off screen then the wide screen.
is there any cheap 17" squared lcd monitors with high res?
call me silly but I dont even know what the 4:3 / 16:9 difference is I know my res's and p/i's though lol.
cab does look good though Malenko and the work looks good too HaRuMaN
« Last Edit: April 26, 2013, 06:23:32 pm by northerngames »
I got a dell 17" for mine for like $35, looks awesome. 4:3, btw. Thats the squared one. 16:9 is the wide one.
my screen is "squared off" its a 4:3 monitor not a 16:9 wide screen. Its a tight fit and not the greatest monitor, but with the SGL rom craftymech its perfect for the application. I didn't buy the monitor that in mine for the application, I am just using parts that are sitting around :)
Im still working out how Im gonna position the guts inside for ease of use and what not.
SNAAKE
excited about that weeweecade :burgerking:
and malenko your setup must be lagging like kray!  :dizzy: I know that monitor isn't native VGA.
northerngames
good to know and not sure how I never knew the difference in the two  :laugh2:
even when I bought this I wanted a 4:3 but went with this vw246H 16:9 and it is great as a pc monitor and hd gaming with 2ms but the classic's look too weird for me on it.
I think a 4:3 with the slg will give me the look I am after though and should be perfect size at 17"
going from the nanao in true 15k to a 16:9 hd just aint the same for me after seeing the two and being use to playing them all native as opposed to now.
Yeah, here is a 17" 4:3 in my MDF prototype (running a DC with VGA cable):
not really. I mean I have no problems playing the games I want. I'm not in a street fighter tourny doing frame cancels and what not, I'm playing sonic the hedgehog on a Genesis emulator and button mashing some Soul Calibur. The monitor was the right price, free ;)
retrostark
nice work malenko. i love sonic!
retrostark
isn't $140 a bit much just for wood?
