Author Topic: iCade replacement artwork  (Read 18693 times)
Man-Machine
  • Last login:October 17, 2018, 03:51:40 am
« on: February 12, 2013, 10:12:39 pm »
If I have the artwork on Illustrator, what are my options to actually replace the iCade artwork?
I'm looking of a simple solution that doesn't include wood sanding or anything like that. Also, I want to have some artwork on the plastic control panel as well.
Thanks.
Drnick
  • Plodding Through Life
Re: iCade replacement artwork
« Reply #1 on: February 13, 2013, 01:47:57 pm »
Vinyl straight over the top of the existing artwork would be simplest.  As for the control panel, same thing but you would have to do some disassembly removing stick and buttons then putting them back in again once artwork was applied.  I am fairly sure you will want laminated vinyl for the control panel.  You can probably get away without laminating the sides although if you have all the artwork printed on 1 sheet it will probably be cheaper then 2 individual sides and 1 x control panel.  (Which was something I didnt think about when I did my artwork).
nayr2
  • Last login:July 28, 2014, 04:26:12 pm
« Reply #2 on: February 13, 2013, 02:48:30 pm »
I'm finishing up an iCade to PC conversion and am looking to do the same. I'm wondering what artwork you chose or created? I'm having trouble deciding what to do with mine.
I peeled the sideart off and sanded it. It mostly came off very easily, and only minimal sanding was needed. I've painted and sanded a nice black finish on it, but I don't think that's needed. Right over the existing artwork is probably your best bet.
« Last Edit: February 13, 2013, 02:53:28 pm by nayr2 »
Man-Machine
« Reply #3 on: February 14, 2013, 04:33:18 am »
I was going to do the same thing you're doing but I wanted a different control panel layout.
Are you going to create a new control panel top made of wood or are you retaining the original layout?
nayr2
« Reply #4 on: February 14, 2013, 11:57:00 am »
I kept the same layout, but replaced the joystick and all buttons.
ridicrick
  • Last login:September 28, 2017, 08:47:51 pm
    • ArcadeSkin
« Reply #5 on: February 23, 2013, 03:13:08 am »
I made templates for the icade and make some skins for them... so far made a FIFjr and Donkey Kong. But if you anyone wants my templates to create their own let me know. I can also print them.
scoobydoo2011
  • Last login:February 24, 2013, 02:27:58 pm
« Reply #6 on: February 24, 2013, 12:53:35 am »
That stuff looks amazing where can I get some like that.
Drnick
« Reply #7 on: February 24, 2013, 11:07:03 am »
Ummm, I guess you speak to ridicrick  :P
You probably can't PM him yet though as you need a few more posts.
scoobydoo2011
« Reply #8 on: February 24, 2013, 02:25:16 pm »
Thank you .
mrtank
  • Last login:July 08, 2013, 06:40:29 pm
« Reply #9 on: July 06, 2013, 07:39:29 pm »
MATE! This is amazing! I got my iCade 2nd hand already setup, but are the original decals optional? also, can you explain the measurements etc for the top panel so house the led etc?
g_block247
  • Last login:March 29, 2016, 03:46:56 pm
« Reply #10 on: July 21, 2013, 08:05:13 pm »
That Fix it Felix skin is amazing dude! nice work  :applaud:
hksrb25s15
  • Last login:August 25, 2014, 09:34:52 am
« Reply #11 on: July 28, 2014, 02:19:06 am »
wow that's sweet, what monitor is that? Or is it a tablet? A iPad?  is that Plexiglas?
nayr2
« Reply #12 on: July 28, 2014, 04:23:40 pm »
It's a replacement iPad2 screen, along with a VGA controller that works with it from ebay. The glass is just a piece of glass that I ordered to the dimensions that fit. There's some wood panels I added to angle the screen and top panel. I just used balsa wood. Inside there's a small laptop, amplifier for the speakers, and the button and led controllers. Since taking that picture I've added a spinner on the front and LED's in the buttons :)
I'm still figuring out what to do for artwork
« Last Edit: July 28, 2014, 04:26:12 pm by nayr2 »
hksrb25s15
« Reply #13 on: July 29, 2014, 12:31:40 am »
Thanks so much, looks great.
davidgilmour
  • Last login:April 11, 2025, 09:01:44 pm
« Reply #14 on: April 10, 2015, 05:22:49 am »
that looks awesome!
  • Last login:Yesterday at 08:38:08 pm
« Reply #15 on: April 10, 2015, 06:08:49 pm »
That's brilliant. I never thought of using the replacement LCD's normally for repair, in an arcade project.  They'd make some really nice smaller-form bartop projects...
Got any links to which ones you bought?
« Reply #16 on: April 10, 2015, 06:17:29 pm »
I'm curious about this as well and agree it is brilliant.
BorgDog
« Reply #17 on: April 10, 2015, 07:07:52 pm »
I've been looking at those screens as well for my next couple bartops as well.  There are quite a few on ebay, most drop ship from china like this one but I also found one from a guy in Michigan for a little more, my guess is he imports a bunch then resells.  The nice thing about the Michigan guy ones are that he mounts the board to the back of the display nice and neat, for more money you can find retina display ones as well :)
« Last Edit: April 10, 2015, 07:12:44 pm by BorgDog »
My Projects:
Slippyblade
« Reply #18 on: April 10, 2015, 07:30:24 pm »
That Michigan guy has a good ad.  Actual information and specs.
« Reply #19 on: April 10, 2015, 07:58:53 pm »
lamprey
« Reply #20 on: April 14, 2015, 11:29:30 am »
What are you using as an adapter from the LCD to VGA? Assuming I read that correctly.. :)
