Author Topic: 28mm to 30mm balltop options?  (Read 1339 times)
1500points
  • Last login:November 20, 2018, 01:44:12 pm
    • How to succeed at Robotron
« on: February 08, 2013, 04:25:16 pm »
Thought I'd avoid a title that said I need smaller balls.
Looking to replace a standard screw on ball top (on a zippyy stick) with a ball that is 28 to 30mm.
Can't seem to find a replacement at the obvious online places.
Are there any options out there for buying a smaller balltop, with the standard threads like most of the balltops out there?
thank you.
chopperthedog
  • Last login:Today at 09:22:11 am
Re: 28mm to 30mm balltop options?
« Reply #1 on: February 08, 2013, 04:38:16 pm »
This was all I could come up with. http://forum.arcadecontrols.com/index.php/topic,129441.0.html
good day.
chopperthedog
« Reply #2 on: February 08, 2013, 04:50:16 pm »
Here's another option I found. But at the time I wanted them the place was closed for a month. http://www.gremlinsolutions.co.uk/products/LB-30.htm
good day.
1500points
« Reply #3 on: February 08, 2013, 04:55:59 pm »
most excellent. will pursue those leads. outstanding and thank  you.
