Author Topic: JVL Systems PDF Manuals and info.  (Read 13652 times)
  • Last login:Yesterday at 08:03:00 pm
« on: February 08, 2013, 01:58:44 pm »
Will copy paste links to info sorted by generation here:
"iTouch" series systems:
iTouch "HD" series systems:
oldgrandpainmi
  • Last login:July 10, 2020, 08:48:17 am
Re: JVL Systems PDF Manuals and info.
« Reply #1 on: July 09, 2020, 11:32:57 am »
do you have any links to manuals showing how to remove the touchscreen/display from a JVL Retro?
« Reply #2 on: July 14, 2020, 12:10:35 pm »
I don't unfortunately the data surrounding JVL is extremely scarce...and only supplied by the manufacturer on a need to know basis.
for the retro, i believe there are 2 phillips screws on the inside in the top and right corners (and a latch maybe?)  the monitor should hinge out if you push it out from the inside.
use caution, it is only held in by tabs at the bottom so you can lift it up and out. so don't go all gung ho tilting and flipping it around.
game_nerd
  • Last login:June 01, 2024, 12:41:14 pm
« Reply #3 on: May 12, 2022, 03:29:32 pm »
I did find a bmi gaming manual for the echo/encore. it's got some illustrations and part numbers for apparently non existent replacement parts.
maybe it will come in handy
