Author Topic: hyperspin won't run with Calamity driver loaded.  (Read 6349 times)
alphadog808
  • Last login:February 09, 2014, 01:17:34 am
« on: January 24, 2013, 02:00:15 pm »
Hey guys,
  An issue I ran into when rebuilding my machine was that hyperspin would not launch with calamity's drivers installed.  When I looked at the logs, it said something about the joystick not being initialized, or something to that effect.  If I ran mame via command line, it worked fine.
I read somewhere about having too many resolutions would cause hyperspin to have problems, but I think they said the symptom was that there was nothing in the logs....I have stuff...;)
I didn't check the amount of resolutions I have in my config file, but I'll check and mess with it tonight.
BTW, I'm not sure exactly how I ended up getting it working, I kept switch back and forth between my computer monitor and arcade monitor and then one time it worked!  haha  But I'd like to know what happened so I can try messing with the resolutions more, if possible...
Calamity
  • Moderator
  • Last login:Today at 03:19:58 am
  • Quote me with care
Re: hyperspin won't run with Calamity driver loaded.
« Reply #1 on: January 27, 2013, 01:16:50 pm »
So did you manage to get HS working?
Steps to create a log:
alphadog808
« Reply #2 on: January 29, 2013, 01:54:58 pm »
Yup, I did, I had to change the amount of resolutions...once I did, everything worked fine.   :P
Tzakiel
  • Last login:March 02, 2019, 12:59:01 pm
« Reply #3 on: October 09, 2013, 01:55:16 pm »
Resurrecting this thread... which resolutions should be safe to get rid of?  Are there ones which groovymame would never want to use?
My Fighter CRT Cabinet Thread: Tzakiel's 2P Cabinet
Calamity
  • Moderator
« Reply #4 on: October 09, 2013, 01:57:55 pm »
Hi Tzakiel, search this subforum about "magic" resolutions.
Tzakiel
« Reply #5 on: October 13, 2013, 09:09:39 pm »
Sorry, I'm dumb. I found the magic resolution thread... Read it. Still not sure what I need to do to be honest. I know I have two options, either limit the # of resolutions available in arcade osd or vmmaker (but I don't know which resolutions are safe to delete) or use magic resolutions, which that thread didn't really explain clearly enough for me. Maybe I just missed the steps somewhere. What do I need to do in order to use magic resolutions and get hyperspin to work?
« Last Edit: October 13, 2013, 09:24:38 pm by Tzakiel »
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #6 on: October 14, 2013, 01:04:14 am »
just limit the number of resolutions in VMMaker to 100 or so..
Tzakiel
« Reply #7 on: October 14, 2013, 03:55:05 am »
OK.  So I haven't actually has to use vmmaker so far... I guess I will download it and see where I can make that change.   Just run it in the groovymame dir or seperate dir?
Sledge
« Reply #8 on: October 14, 2013, 07:02:36 am »
wait.. so you're trying to fix something that you haven't even done yet?
regarding VMMaker.. read the instructions :)
and look in the .ini
Tzakiel
« Reply #9 on: October 14, 2013, 08:43:19 am »
Sledge, I am trying to fix the fact that Hyperspin doesn't launch. Groovymame was working fine with all of the resolutions without using VMMaker. So, I've never downloaded it. Just installing the crt_emu drivers and using groovymame has worked perfectly so far, and so I didn't seem to need vmmaker. Does that make sense? So now if I download vmmaker (which says it generates modelines) I am just not sure what the purpose is vs. the crt_emu drivers and arcadeOSD. But, if it helps me get hyperspin working, I will take a look!
« Last Edit: October 14, 2013, 03:40:05 pm by Tzakiel »
Calamity
  • Moderator
« Reply #10 on: October 14, 2013, 06:54:32 pm »
Hi Tzakiel,
I always try to help new users but I honestly think this topic has been covered a hundred times, just take some time to read the threads about Hyperspin, magic resolutions, vmmaker. Just make sure to grab the most recent version (1.3c) here: http://mame.3feetunder.com/windows-ati-crt-emudriver/
The file named vmmaker.ini was meant to be self-explanatory. Keep vmmaker in its own folder. Setup paths as required. Just make sure not to forget enabling magic resolutions by using this option:
ModeTableMethod_XML = 2
... run vmmaker, restart... etc.
Tzakiel
« Reply #11 on: October 14, 2013, 06:59:55 pm »
Great, thanks. I will give it a try. I know there is a lot out there but to a new user it's pretty overwhelming. I hope some day it can be captured in a guide or post for new users. Id even be willing to help put it together once I have everything figured out myself.
Appreciate your help.
