Author Topic: IPAC 4 gone haywire  (Read 2122 times)
Rydon
  • Last login:October 03, 2013, 06:32:49 pm
IPAC 4 gone haywire
« on: January 12, 2013, 03:16:01 pm »
Hey guys
  I am in some serious $#%& right now.  I wanted to alter one of my buttons with the ipac4 so I downloaded the winipac, after messing around with the program, I found out the I can do the ctrl+alt+p in notepad to alter a key press, so I wanted to do this.  after I got out of winipac, I discovered that all of my keys are completely different.  I tried to go into the config with ctrl+alt+p and I see no option to do the reset.  What is going on here.  If I try to do a manual reset, and tell the config in notepad to alter my 1p joystick up to the up arrow, and then hit e to save, it will not save.  I really just need this thing to be factory reset.  Can any help me with this?  I cannot see why I can't get the ipac4 back to the original settings.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: IPAC 4 gone haywire
« Reply #1 on: January 12, 2013, 05:52:43 pm »
Getting back to original settings is just a matter of loading the "Default 4" IPC file into WinIPAC and programming the board with it. The default files are installed with the program, in the "templates" folder.
Rydon
« Reply #2 on: January 13, 2013, 11:04:24 am »
Thank you so much for the help.  I really appreciate it.  This worked great and now the iPac is responding fine.  Thanks again!
