Author Topic: 9v 1000ma too much for LEDWiz?  (Read 976 times)
supafraud
  • Last login:January 13, 2013, 12:55:11 am
« on: January 05, 2013, 11:26:21 pm »
Hello, so I'm pretty sure I've read the docs correctly that the LEDwiz can only handle 500ma but I thought I would ask anyway. I have an old adapter laying around that is 9 volts at 1000ma and would love to use it if it will work, but think it will blow out the board does anyone know?
  • Last login:September 20, 2025, 07:17:24 am
Re: 9v 1000ma too much for LEDWiz?
« Reply #1 on: January 05, 2013, 11:43:50 pm »
No,the supply (your old adapter) is good for 1000 MA.  The load (total of all outputs on the ledwiz) is what you have to worry about.
If the total load is more than your power supply (1000 MA) then you might be in trouble.
I think the LED Wiz that you are thinking of is looking at the USB power supply.
The LEDWiz (Im pretty sure) should be good for 500 ma per channel. So if your total load is less than 1000 MA you should be ok (unless the total load is on one output (channel ) of the LED Wiz, then its 500 MA Max)
I hope this makes sense. The total load (all outputs of the ledwiz) should not be greater than the power supply (in your case 1000 MA). Also, the load on any channel (output) of the LEDWiz should not be greater than 500 MA.
supafraud
« Reply #2 on: January 06, 2013, 01:26:36 am »
Ok, I get it now, thanks for the info. Think I need to go to RadioShack anyway because I'm powering #47 bulbs and they're 6 volts. I'm guessing 9 would fry em
